Question about Kenwood Dishwashers
Replace drain hose on kenwood KID60B12 dishwasher
How to replace drain hose. How do I get to it to replace it?
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: LG dishwasher drain hose
You will have to remove the dishwasher from the cabinet, lay it on it's side, and remove the bottom access cover to get to the end of the hose. (it's usually not as bad as it sounds)
Posted on Mar 18, 2009
Macmarkus
  • 2605 Answers
SOURCE: Need to replace drain hose on bosch dishwasher model shv4303UC/11
Hi, Welocome to Fixya. You just need to remove the small plastic holding tab at the back where the hose exits the machine. Then along the left side ( from the front...right side from back ) remove the side panel and the hose will simply pull out of place. Hope that answer's your question, let me know how you make out. Thanks for visiting "fixya" today. Please take a moment to leave a comment and also rate the solution provided accordingly. Good luck. Macmarkus :)
Posted on May 29, 2010
Macmarkus
  • 2605 Answers
SOURCE: the dishwasher does not drain, i just replace my
Hello, Welcome to FixYa. I just came accross your post and immediately I thought, " drain plug in garb not punched out" this is very common when a new garb or dishwasher is installed..so much If I had a dollar for every one I saw or heard about I could be paid a couple of trip charges. If you haven't already done so, remove the drain hose from the garb and knock out the stop inside the spout. See your installation guide/owners manual ( for the garb/disposer ) if you still have it, that should show you "where" and "how". Let me know either way and I'll help further if necessary. Regards, Macmarkus :)
Posted on Feb 22, 2011
SOURCE: GE drain hose
take the bottom cover off the front of the machine. you may be able to reach the hose clamp that holds it on. if not, you will have to pull the dishwasher out. remove the screws securing it to the countertop and slide it out. then you can easily get to the clamp. remove clamp from both ends of drain line and replace. easy as pie
Posted on Dec 07, 2011
Kenwood KID60B12 Dishwasher F2 Fault code
it seems you a blockage.. can you hear the pump running?if you can you will need to unstop it I have done it with just a cloth hanger coming from the front in put side
Jan 01, 2016 | Kenwood KID60B12 595 mm Stainless Steel...
How to adjust height
there are usually 4 feet at the bottom that are adjustable by a couple of centimeters to bring it to right height & level it.
Apr 12, 2015 | Kenwood KID60B12 595 mm Stainless Steel...
Kenwood dishwasher
You will have to remove it from its installed location. This means unhook the water supply and drain hoses. Then you pull the screws out that hold it to the counter top. Then slide the unit out until you can see the back. The rear legs usually screw in and out to raise and lower the unit.
Aug 01, 2014 | Kenwood KDW243A Builtin Dishwasher
E4 showing on the panel KDW60X10
The Kenwood KDW60X10 shows the E4 code when there is a water leak or a problem with the float switch (or it's PCB board connection). This could be a leak at the tank, the hose, or that the drain pump's anti-flooding system has been tripped.
Disconnect the dishwasher from power and the water line. Look for signs of a water leak under the unit. If the hose is leaking, you may be able to replace or reseat the drain hose. (Also make sure that there are no kinks in the hose.) Note: sometimes the leak is in the plastic where the drain hose connects to the dishwasher. That is harder to fix.
If the tank is leaking, replace the entire unit. For the other possible problems, you should consult a repair tech to narrow down the issue. Float switches are easy enough to replace; the PCB board and the anti-flooding system are not as easy to reset.
The manual for your dishwasher is available here: http://www.partmaster.co.uk/company/partmaster/manuals/Kenwood%20KDW60X10.pdf .
I hope this helps.
Apr 12, 2012 | Kenwood Dishwashers
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Kenwood dishwasher Comes up E3
I do not know the Kenwood dishwasher, hence I do not know what the E3 error is, but many dishwashers require a sustained pressure of at least 30 psi.
Can you please post the model number of your Kenwood dishwasher?
Apr 11, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Water won't drain completly
Start by cleaning the drain hose. this is a common issue when food builds up in the drain hose. most of the time it is what is called the air gap. the little metal looking thing on your sink. take the cap off and then there is another small cap underneath usually white that you would push 2 tabs in to get it out and you would see any debris inside.
Nov 08, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
47 people viewed this question
Top Kenwood Dishwashers Experts
ashburton
Owen Barnes
ray gallant
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
