Question about Annovi Reverberi Rmw 2g24 Vertical Shaft Pressure Washer Bare Pump
Low Pressure Whenever you press the trigger there is not more pressure.
    Sergeant:
  • 195 Answers
Very little info to go on here. Could be a valve issue or a packing issue or an unloader issue. If it has been sitting for any length of time which tends to be the case, then an unloader valve is most likely the culprit. Good luck
Posted on Apr 15, 2017
I switch the pressure washer on motor starts pressure builds up motor stops. OK pull the trigger on the lance the moter starts sounds different water pressure low. Release trigger motor still runs.
It isnt very clear your explanation of the problem but what type washer do you have first? It sounds like you have a bad unloader or need a new variable nozzle tip. Can you explain in more clear detail. Thanks
Feb 16, 2015 | Garden
My water pressure does not hold the pressure when i pull the trigger
does it hold pressure at idle? (trigger released) and then hold a lower pressure with trigger pressed? If so you probably have worn or wrong size nozzle
Jan 16, 2013 | Garden
Low tire pressure indicator came on today. All tire are at right pressure. How to reset?
BMW low tire pressure sensors use the speed sensors at the wheels to detect a flat tire. If any one tire is much newer or older than the other three, the warning will trigger. Tire chains tend to set it off as well.
There should be a button on the console that has a pattern that looks like the low pressure warning light - the profile of a tire with an explanation point inside. After you start the engine but before moving, press and hold that button until the warning light in the instrument cluster illuminates yellow. Then drive normally. That should re-initialize the tire pressure warning system.
Jan 25, 2011 | BMW 325 Cars & Trucks
Let go of wand trigger pressure will not come back
spill valve is stuck and needs to be cleaned and greased common problem....also check all connections for blockage in line
Jul 21, 2010 | Karcher 2500 PSI Pressure Washer
Loud repeating noise until the water trigger is pressed
Check the pressure washer for leaks. That sound is probably the unloader valve recycling as the machine slowly looses pressure and needs to build it up again to max pressure.
Dec 15, 2009 | Garden
Karcher 2400 psi blaster When you release the trigger it will not pick up pressure when you use it again
To determine if your problem is due to an easily replaceable part, follow these steps:
1. Connect the water supply hose, the pressure hose, and the wand WITHOUT any nozzle tip.
2. Turn on the water supply, and press the trigger until water is smoothly running out of the nozzle
after any air is all purged out. Release the nozzle trigger.
3. Start the engine, and let it warm up for about 30 seconds.
4. With the engine running smoothly, press the nozzle trigger. The water should flow out of the nozzle (without the tip installed) at a faster rate, while the engine noticeably loads down as it used to do before your "no pressure" problem. If it does not load down, turn it OFF, and disconnect everything, and contact a Karcher repair facility.
5. If the engine does load down, release the trigger, and install one of the nozzle tips (not the black one).
6. Press the trigger, and the engine should load down, and you should have normal pressure from the wand. After you release the trigger and press it again, you will probably again have no pressure, and the engine will not load down. Removing the nozzle tip, pressing & releasing the trigger, and re-installing the tip should give you normal pressure again, but releasing the trigger will cause no pressure until you again remove the tip, press the trigger, and re-install the tip.
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace a $5 (maybe) part, and it took about 5 minutes.
Sep 12, 2008 | Karcher 2500 PSI Pressure Washer
There is no pressure
This is caused by a bad UNLOADER VALVE, which is located under a black cap with a metal button on it located on the top front of the pump. I don't know if you can purchase the replaceable parts from a Karcher repair shop, but when a neighbor & I took his washer to a repair place, it looked pretty simple to do this repair, and he was charged about $60 to replace about a $5 (maybe) part, and it took about 5 minutes.
Sep 11, 2008 | Karcher 2500 PSI Pressure Washer
Annovi Reverberi Rmw 2g24 Vertical Shaft Pressure Washer Bare Pump Logo
83 people viewed this question
Top Annovi Reverberi Garden Experts
Bill Boyd
jeff chenault
jeff chenault
Keith Poitier
Are you an Annovi Reverberi Garden Expert? Answer questions, earn points and help others
