Question about Food Mixers
Disassemble ksm5 noisy gear even at slow speed. How to get access to the motor and what tools to use.
2 Suggested Answers
fixyathing
  • 341 Answers
SOURCE: Motor runs but beaters do not turn.
I challenge you to do-it-yourself...you can do it. Just be careful when removing it apart. I advise you to take a video or get some snap shots while you are at it. This way, if some springs snaps out, I assume that you took a picture of it already.
Usually those plastic gears are the problem. Goodluck!
Posted on Jan 13, 2009
Kitchenaid proline ksm5
To lube the planetary you take off the drip ring and knock out the pin that retains the planetary to lube the planetary gear. If you want to do the gearbox you need to continue and split the gear cases. Back cover off and 9 case screws. That's it, you are in where all the grease is.
Sep 01, 2014 | KitchenAid Food Mixers
Kitchenaid mixer K45SS only has one speed, slow. Have taken apart and regreased the machine. I plugged it in while the planetary head was off and it went through the speeds as normal, but as soon as
Did you clean the are around the variable-speed control lever?
Please be sure to unplug the mixer BEFORE disassembling the mixer.
http://www.ereplacementparts.com/kitchenaid-k45sswh0-classic-stand-mixer-parts-c-114958_114959_115060.html?page=4
http://www.ereplacementparts.com/article/11983/How_to_Replace_the_Speed_Sensor_and_Control_Board_on_a_KitchenAid_Pro_6_Mixer.html
Jan 07, 2014 | KitchenAid K45SS Classic Stand Mixer
Is a kitchen aid model # KSM5PSAC the same as KSM150SP?
The KSM5 and the KSM150 are different mixers. They are both 5 quart mixers and use the same gearing and motor. However the bowl design is different. The KSM5 is a 5 quart bowl lift, which means the bowl locks into the arms of the mixer and raises towards the head of the mixer, where the ksm150 mixer is a artisan mixer, which is also a 5quart mixer, but the head of the mixer tilts back and the bowl twists into the base ring to lock into place. These two mixers will take different bowls and beaters.
Thank you,
Colleen
Customer Service
MendingShed.com
Jan 27, 2013 | KitchenAid KSM150PS Artisan Series Stand...
When turned on gear 1 mixer lately slipped to gear 2 immediately. I took back cover off and cleaned everything out by lifting the electrical element (?) and after mounting everything back on the mixer does...
You need to adjust the mixer speeds. Obtain a copy of the KSM5 Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 2
Jul 04, 2011 | KitchenAid KSM5PS Heavy Duty Stand Mixer
How do you remove the top of a Anvil 20 qt mixer
To the best of my knowledge that is a reduction drive / direct motor connection mixer. No belts just bearings and gears. It has been far too long and I honestly can not tell you how to remove the cover. I do remember that were screws under the chassis of the motor / gear section. Real bad case of long time no do... here. You might have to remove the drive head to access the top cover screws. Wish I could have been more of a help. Just in this case it is one of those it needs to be in front of me things.
Jan 13, 2010 | Food Mixers
So I shreded the nylon gear in my K5SS 325W. How
Hi DELUNAY. The only way to tell if your speed control assembly is bad it to remove it and test it a local repair shop, but I think from the symptoms you describe, you’ve already answered your own question and your speed control assembly is shot. The fact that your motor is not making any noise indicates to me that it’s not getting power. That can only be caused by two things; a bad speed control board or a burned out electric motor. When you shredded your nylon worm gear, did the motor exude a ‘bad/burnt’ smell (other than possibly ozone)? If not, then I would look at replacing your speed control board/assembly.
Since you know you’ve got to replace the worm gear, you might as well replace the speed control assembly. The inspection and troubleshooting of the mixer transmission is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the correct Part List manual around when you start to disassemble your mixer. If you're lacking one, you can download it from the KA website (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case use KSM50P and then select the first files under Parts List (definitely check to see if it matches your mixer. If it doesn’t, continue to look at other manuals until you find the correct manual that does match.)
Turn to pages titled ‘Case, Gearing & Planetary Unit, for the disassembly, troubleshooting, and reassembly of your mixer, along with all the parts. This is where you’ll find your
Besides your shredded worm gear, you can check for any other unseemly wear and tear on the other gears, etc. You may find more parts that need replacement than just a bad gear. You should also consider replacing the grease, particularly if there are gear particles suspended in it.
Besides needing a replacement gear and grease, you might consider replacing the gasket, too. I recommend using a food-grade grease that you can order online (although I’ve seen automotive bearing grease used too – your call).
As far as parts go, here are five potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com; and Grainger.com. You should search for ‘food grade grease’. Prices can vary widely between vendors, so do your comparison shopping.
It can be messy but quite gratifying to diagnose and repair your mixer yourself. Oh and don’t forget to replace the speed control board and associated components, tool
Here are some links to several excellent websites that detail the disassembling/greasing and reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it. hslincoln
Dec 10, 2009 | KitchenAid K5SS Heavy Duty Commercial...
MY KITCHENAID MIXER MODEL # KSM5 TURNS ON BUT THE BEATERS WONT TURN. I MIXED UP SOME PIZZA DOUGH AND GUESS I BROKE SOME GEARS OR SOMETHING. PLEASE HELP!!!!!!!!! THANK YOU
The most common part to fail in this mixer is the worm gear:
http://kitchenaidmixerspares.co.uk/Home/tabid/36/p/Mixer-Part---Worm-Gear-and-Bracket-240309-2/ProductID/103/CategoryID/17/Default.aspx
Oct 31, 2009 | KitchenAid K45SS Classic Stand Mixer
Mixer does not function at "stir" and lower speeds Does OK at mid and high speeds
Remove the brushes. Two black screws, one on each side. Pay close attention to orientation. MUST INSERT THE SAME EXACT WAY! Use electrical contact cleaner. I said electrical contact cleaner, put the WD40 back in the drawer!!! Using electrical contact cleaner, clean the contacts. Now clean them again, now repeat two or three more times. Spray SOME, meaning a little, into each hole. Reassemble and try it out. If this does not fix the problem refer to the section on removing the cover to access the motor and gears. disassemble clean the motor's brush surface and the contacts. if you don't know what I'm talking about then stop and call a pro.
This is a very common reaccuring problem with these things. Especially when meat grinding or cookie doughing with it. If you move to replace, get a stronger model, like the 500 or the 600. No, I do not sit around repairing mixers all day. I just happen to know a lot about the ones my wife has destroyed. Some two or even three times. after a while it pays to go get the right equipement.
Mar 15, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Hobart A120
Yes it does sound like lubrication. And if they start out noisy, they tend to stay noisy. There is inspection dust caps under the top cover.
Apr 25, 2008 | Food Mixers
Food Mixers Logo
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
