Question about Vizio E550vl 55-inch Full Hd 1080p 120hz Lcd Hdtv
VIZIO E550VL firmware update
Looking for the newest firmware update for the VIZIO E550VL, known to resolve the shut-off and going to standby issue.
2 Suggested Answers
  • 2609 Answers
SOURCE:
Change the power board or look for bad capacitors, this is a common issue when filters are going bad..Good luck
Posted on Nov 30, 2017
When I turn off my vizio 55 in smart tv, which is 11/2 yrs oldthe screen goes gray and does not shut off completely. Only input cable w/o cable box.
Try unplugging it for 10-15 minutes then plug it back in and try it again. If that still doesnt work resetting it then its most likely a software/firmware issue with the mainboard. Smart tv's are not so smart. Its like having a computer and tv built into one. Sometimes they just need a hard reboot to clear an issue. If that doesn't fix it see if there is an update available for the tv's firmware, usually in the setup and service menu on Vizio smart tv's.
Dec 31, 2017 | Vizio Televison & Video
Tip
Known ram issue
With the aspire 5100 series there is a known issue with ram that causes all sorts of glitches, freezing and reboot. Upon a ram test, the ram will say errors accross the board and replacing the ram will yield the same result. The fix is to update the bios firmware and it will resolve the ram issue. Go to acer's website and click on support and drivers, type in your model number and get the latest bios update..follow the bios update instructions on the site.
on Apr 26, 2009 | Acer Aspire 5100 Notebook
DIAGNOSING A VISIO E550VL TV THAT HAS NO PICTURE BUT DOES HAVE SOUND, TWO OF THE INPUTS ON THIS UNIT HAVE QUIT, I JUST REPLACED BOTH THE MASTER AND THE SLAVE BACKLIGHT INVERTERS WITH NO SUCCESS.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 07, 2015 | Vizio E550VL 55 in. LCD HDTV
White dots on screen
Most likely T-Con PCB. Part Number varies (See Below)
http://www.shopjimmy.com/tvs/tv-t-con-boards?restrictBy[known+models]=VIZIO+E550VL
Nov 25, 2013 | Vizio E550VL 55 in. LCD HDTV
VIZIO E550VL
Replace the main board the eprom has an issue. You can get the replacement main board from www.tvcircuitboards.com
Dec 14, 2012 | Vizio E550VL 55 in. LCD HDTV
Getting hdmi problems between vizio e550vl and uverse
more likely the receiver or a connection than the set
Aug 27, 2012 | Vizio E550VL 55 in. LCD HDTV
Vizio m550sv turns on and them immediately turns back off
Call VIZIO Support 1-877-698-4946 and discuss the issue. Their sets are run by software "firmware" and it may not have updated proberly when you bought the set. I have had the same problem and it went away after a firmware update. VIZIO will ask you to run a :power discharge" scenario which means you Completely Unplug the unit and PRESS the Power Button on the Back of the Set...HOLDING IT DOWN FOR 3 MINUTES. However, thay may not resolved the issue unitl the firmware is completly updated. This takes a while.
Dec 28, 2011 | Vizio M550NV 55 in LCD HDTV
I have a vizio 55 in. e550vl the hdmi ports quit working when lightning hit a tree by the house i think maybe a surge came through the satellite if i was to replace the main board would that fix it i...
I am having the same issue with our Vizio E550VL TV. Does your TV show No Signal on the screen? I was able to get regular AV to work with the Yellow, Red, and White cable to work but none of the HDMI ports would not work. If it does not power on at all it may be the power supply. I had to order the main board to get it to work correctly. Vizparts.com is where you can order it from.
Aug 10, 2011 | Vizio E550VL 55 in. LCD HDTV
Linksys wvc200 keeps freezing up, also has a problem with internet explorer 8 & shuts the program down. just switched it to a new computer with windows 7 professional. Already upgraded firmware &...
Go to the Linksys website, download the NEWEST drivers for your camera and operating system. It seems that you've got a driver problem. Maybe there's a patch that's needed. You might check with Microsoft to see if there is.
As for Explorer 8, you should normally stay away from Microsoft software as a rule of thumb. Their stuff is buggy and full of holes. Are you "locked" into using Explorer? Use another browser!!! Use Mozilla, or Firefox, maybe Opera, anything but Explorer!
If that doesn't resolve your issues, then I would begin looking at the hardware. Specifically, the camera and cabling. Try with a different camera (same Maker and Model). Maybe the issue is with THAT camera and works fine with another. Same with the cabling, try a known good cable, or better yet, a NEW cable. Eliminate the variables, narrow down the problem!
Jul 21, 2010 | Linksys WVC200 Network Camera
I turn on the gogear sa6045, the loading screan appears and shuts off at 35%.
Reset the player using the pinhole. If it freezes again, you need to update the firmware to resolve the issue permanently.
To update the firmware correctly:
Download the newest version of the Philips Device Manager:
www.usasupport.philips.com - change your country/language as needed
Enter in your exact model #
Click on the link for your exact model #
Click on the Software & Drivers section
Click on "Firmware Upgrade Software"
Install the new Device Manager
Open and run the "Update" tab
-Tha Mp3 Doctor
Apr 02, 2009 | Philips GOGEAR SA6045 MP3 Player
Vizio E550vl 55-inch Full Hd 1080p 120hz Lcd Hdtv Logo
123 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
