Cell Phones Logo
A
Anonymous Posted on Apr 19, 2014
How to access blocked call list on wx416
Need to edit my blocked calls
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
How do I unblock a phone number on my uniden dect 6.0 phone
Call block entry options:
With the phone in standby, open the call block list and find the entry you want.
Press Menu/select to open the individual entry menu. Choose one of these options:
  1. Edit (Handset only) Edit this entry. The phone will prompt you to edit the name & phone number.
  2. Delete Erase this entry from the list & allow calls from this number.
MOTOROLA WX416 HOW CAN I SET UP VOICEMAIL FOR THIS PHONE
I would suggest to contact your carrier, sometimes VM needs to be reset so you can have access. If you are activating it, make sure you've been provided with the correct number to dial.
Sp codes for motorolla wx416
http://sim-unlock.net/simlock/New_Motorola/WX416 This may help, but there is more than likely a fee involved.
3helpful
2answers
I want to unblock a call on a panasonic cordless phone?
Access your blocked call list. Go to the main menu and scroll down; it should be one of the options listed there. Push the "Enter" key to access the blocked list once it's highlighted.2 Scroll down the blocked call list until you find the number that you want to unblock.3 Highlight the number and delete it from the phone's list.
  • 0helpful
    How do I block phone calls
    Please select in following order
    go to "Settings"
    "Calls" tab
    "Manage calls"
    "Accept calls"
    select "None" to block all calls or select "Only from list" to receive selected calls.
    For "Only from list" you have select "Edit" from the right button which will show you "Accepted list" in which you can add selected callers.
    6helpful
    2answers
    HOW CAN I BLOCK A NUMBER ON MY LG GM360
  • 1. Turn your phone on and locate the Settings menu. "Settings," scroll to "Call" select "OK" to enter the menu.
    2. Scroll down to "Call Reject" and select this option.
    3. Select "Call Reject List" on the next menu. Enter the ten-digit number of the person that you wish to block and confirm your selection. That number will now be blocked from you phone.
  • If you are happy with the solution then please rate this answer.
  • 3helpful
    3answers
    No manual and am receiving unwanted calls at night just became threatening how do i block them
    Using Call Block
    If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
    The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
    Blocking incoming calls
    1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
    2. If you want to block the call and add this number to the call block list, press Block.
    3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
    Call Blocking menu options
    1. With the phone in standby, open the menu and select Call Blocking.
    2. Choose one of these options:
    • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
    • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
    • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
    1. With the phone in standby, open the call block list and find the entry you want.
    2. Press Menu/select to open the individual entry menu. Choose one of these options:
    • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
    • Delete - Erase this entry from the list & allow calls from this number.
    I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
    22helpful
    I can not remove call block from my phone. model kx-tg6414
    I had a similar problem with a KX-TG6445. To edit the call block list from the handset press Menu then # 2 1 7. This will take you to the call block menu where you can edit or erase the blocked numbers list.
    Top Samsung Cell Phones Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
