Question about Brother MFC 9600 All-In-One Laser Printer
Brother mfc hex dump mode reload paper - Brother MFC 9600 All-In-One Laser Printer
mbase213
  • 728 Answers
SOURCE: Brother MFC-9440CN
Hey andydfw,
If it's those gears that are slipping, 1) you can look at the way the round gear is seating. It needs to be inline with the teeth, if when your looking at the teeth you should notice one of the gears might have some missing teeth, or is worn down to the point the the connecting gear doesn't catch. This will only tell you were the gear problem is.
To repair it: Well, you'll have to go through brother to get a replacement part, and I've seen in the past where they don't sell anything but the basic consumables. How old is the printer? If it's under warranty, Go HERE, and put in your zip code that will get you someone close. If it is under warranty, then it no charge to you to have it repaired. If it not under warranty, he will have both of those gears. He'll examine the threads, and he can determine which one is slipping, or what's wrong with it. It normally doesn't make that type of noise otherwise their something a bit more complicated that warrants seeing an authorized repair guy.
Let me know how it goes.
Thanks Mark
Posted on Oct 18, 2009
pineworks
  • 4041 Answers
SOURCE: problem paper jam printer brother no mfc-490cw
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 27, 2010
machambi
  • 194 Answers
SOURCE: Brother MFC- 6490CW 6wks old Screen shows "Error
To adjust your Brother machine's paper type and size settings follow the instructions listed below:
To get the best print quality, set your Brother machine for the type of paper you're using.
You can use seven sizes of paper for printing and copying: Letter, Legal, Ledger, A3, A4, A5, and 4 x 6 in (10 x 15 cm).
You can use five sizes for printing faxes: Ledger, Letter, Legal, A3, and A4.
When you change the size of the paper you load into your Brother machine, you must also change the machine's Paper Size setting.
  1. Press Menu.
  2. Press the up or down arrow key to select General Setup.
  3. Press OK.
  4. Press the up or down arrow key to select Tray Setting.
  5. Press OK.
  6. Press the up or down arrow key to select Tray #1 or Tray #2.
  7. Press OK.
  8. Do one of the following:
    • If you selected Tray #1, please follow these steps:
      1. Press the left or right arrow key to select the paper type you want to use.
        - You can select Plain Paper, Inkjet Paper, Brother BP71, Other Glossy, or Transparency.
      2. Press OK.
      3. Press the up or down arrow key to select Paper Size.
      4. Press the left or right arrow key to select the paper size you want to use.
        - You can select Letter, Legal, Ledger, A3, A4, A5, or 4 in x 6 in (10x15cm).
      5. Press OK.
    • If you selected Tray #2, please follow these steps:
      1. Press the up or down arrow key to select Paper Size.
      2. Press the left or right arrow key to select the paper size you want to use.
        - You can select Letter, Legal, Ledger, A3, or A4.
      3. Press OK.
  9. Press Stop/Exit.
Posted on Jan 02, 2011
  • 3 Answers
SOURCE: brother mfc-8480dn no paper error I have a new
Open the file you are trying to print, go to "file", "page setup", "Paper" and choose "Default tray" under paper source. It may give you an error message that the margins are outside of the paper. Click on "Fix this", then you can print. I had the same problem.
Posted on Jun 02, 2011
kphormel
SOURCE: Brother MFC-9840CDW says no paper when trying to
I had the same problem and in trying to troubleshoot it, I found out it was getting "No Paper" with just one Word document. I went into "Page Setup" and then "Page" for that document, found paper sources were set to "Manual", changed them both to "Page 1", then re-sent document to print and it worked!
Posted on Oct 24, 2011
How do I reset dcp-8045d hex dump mode
Probably the easiest way to turn off the Hex Dump mode would be to reset all printer settings. There should be a reset menu that will allow you to reset the printer to factory defaults. After which it should recognize the new ram and print normally.
Apr 02, 2015 | Brother DCP-8045D All-In-One Laser Printer
MY BROTHER MFC 9440CN KEEPS SAYING NO PAPER RELOAD PAPER IN MP TRAY
not sure if your on copy mode or print mode ..close the MP tray door....turn off then on go to general setup select tray 1. not sure if your on copu mode or print the machine wants you to add paper to the tray that needs it. if you add paper dowes it still say"add paper" .if this is the case then the tray sensor is 1)broke2) pushed out of the way folded3) tray feed roller are not installed correctly no allowing sensor ..make sure your printer settings(properties) are set the that tray.
Oct 16, 2014 | Brother MFC-9440CN Laser Printer
I have Brother Printer MFC-8890DW. It says no paper but there is paper in it. The red light is on. Please let me know how I can fix this problem. Thanks.
If your printing from windows you might need to change the tray settings in the driver.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347&Sympt=When+I+try+to+print+from+Microsoft+Word+or+another+program%2c+I+receive+a++message+stating%3a+No+Paper%2c+Reload+paper+in+MP+Tray+or+Insert+Paper+Manual+Feed.++What+can+I+do%3f&Model=1365&ProductGroup=5&Keyword=no%20paper&ProductID=MFC8890DW
Sep 08, 2010 | Brother MFC-9840CDW Laser Printer
DCP 8045D Display says Hex Dump Load - What does this mean - How do I get rid of it
I resolved the " Hex Dump Mode" problem
Step1: switch off power
Step2: press and hold Stop/Exit ( Red Color Key ) switch on power supply .......
now no " Hex Dump Mode" problem
Jan 19, 2010 | Brother DCP-8040 Copier
Brother MFC-9440CN
Hey andydfw,
Thanks Mark
Oct 18, 2009 | Brother MFC-9440CN Laser Printer
Mfc 8460n dr mode in use
The message DR mode in use or BT Call Sign On will appear on the display of the Brother machine if you attempt to change the receive mode from Manual to another mode when the Distinctive Ring feature (BT Call Sign) is turned ON. If you want to change the Receive Mode, set the Distinctive Ring feature (BT Call Sign) OFF.
  1. Press Menu or Menu/Set.
  2. Select Fax => Miscellaneous or Tel Service => Distinctive or BT Call Sign.
  3. Press the Up or Down Arrow key to select off. Press OK or Menu/Set.
  4. Press Stop/Exit.
Jul 16, 2008 | Brother Office Equipment & Supplies
MFC 8660DN
"MP" means "Manual Paper" Tray. Is paper in the manual paper tray or the main tray?
Jun 03, 2008 | Brother MFC-8660DN 5-in-1 Laser...
Error Message
Clean the paper sensor located at the centre of the mechanism .
Switch ON the printer While holding Feed key down, Printer will enter into self test mode, it will stop after printing self test label.
To take out priter from HEX DUMP mode press feed key for 3 seconds. now printer is in Normal working mode.
Try feeding labels, only one label should advance at a time.
This is the calibration procedure.
Feb 13, 2008 | Intermec EasyCoder PC4 Label Printer
Need User Manual for Brother MFC 9600 All In One
Here's the link; http://www.amazon.com/Brother-MFC9600-Flatbed-Laser-Multifunction/dp/B00004U4A0 Under "product details". Hope this helps :)
Sep 11, 2007 | Brother MFC 9600 All-In-One Laser Printer
Brother MFC 9600 All-In-One Laser Printer Logo
81 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
