To help you troubleshoot the scanning issue with HP Envy All-In-One printer, it is recommended to download and install 'HP Print and Scan Doctor' which will automatically diagnose the issue and try to resolve it. To download the tool, please find the link given below and follow the instructions given under 'How do I use the Fix Scanning feature?' topic: http://support.hp.com/us-en/product/HP-ENVY-4500-e-All-in-One-Printer-series/5304875/document/c03286146/
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports. Steps to Resolve the Printer Offline Issue: Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues. Steps To Run the HP Scan Doctor
•Open the HP Scan Doctor tool by double tapping the symbol.
•Start- - >Select your printer- - > Fix Printing
•Then the list of issues displayed on the screen as result.
•If the tool shows the white checkmarks at that point there is no issue.
•If the tool shows the white wrench then the issues are found and repaired
•If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
•If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues. Step 2:
Set Your Printer as Default Printer
•Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
•If you can capable print implies your printer is online.
•Officejet 4650 keeps going offline then proceeds with following step Step 3: Check Whether You Connect With Correct Port
•Go to printer- - > Printer Properties - >Port
•For USB association utilize USB or DOT4
•For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
•Update the printer firmware which may resolve your issues
Step 5:
•Manually connect the wired or wireless connection Step 6:
•For network connection just you have to add the second printer to your Windows.
•Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
•Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
I've never HAD nor FIXED your model, but have fixed other HPs with different problems before. Re: your hp envy 4500 model printer: I researched a little, finding this:
great product, January 12, 2014
Love the printer and it's performing great. I was thinking of giving this nice printer four 1/2 stars, because the direction should have emphasized more clearly that the paper holding tray must be pushed all the way back in to the printer not just the paper. So when you think the tray is all the way in give it another push. because one can not continue with any of the installations. It would not be fair to the product itself, to write negatively.
Found the above here: Page 4: http://www.amazon.com/HP-Envy-4500-Wireless-Printer/product-reviews/B00CIDQ470?pageNumber=4 or read more here about the paper tray:
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/HOW-TO-PULL-OUT-THE-PAPER-TRAY-ON-ENVY-e4500/td-p/3071717 It looks like the Paper Tray is persnickety on this model... Hope this leads you to a solution. {P.S. Recently when my almost 5 yr. old HP printer died-for good- I bought a "Brother" because I found they give you toll-free Tech Service "for the life of the printer"... and that's what I like!}
Here is download page from HP HP Deskjet 3920 Printer - Download drivers Chose language and OS version. After downloading the file, double click on the downloaded file to start printer setup wizard.
Keep printer unplugged when you start installing files.
