Broderbund Print Shop Pro Publisher 11 Logo
A
Anonymous Posted on Apr 19, 2014
Canot install print shop v11 on vista - Broderbund Print Shop Pro Publisher 11
How do I install print shop 3.5 on Vista Home?
Insert the disc into the DVD drive in your computer. The installation should begin automatically or give a pop-up asking you what you would like to do. Select Run Setup.exe. Note: If the installation does not begin automatically follow these steps: Click on Start. Click on My Computer (Computer on Windows Vista and Windows 7) Right Click on the DVD drive containing The Print Shop 3.5 disc. Left Click on Open. Double Left Click on Setup.exe. The installer will now search your computer to make sure you have the required Windows Updates in order to install The Print Shop 3.5. If it detects that you are missing an update the installer will prompt you to install these now. Once the updates are complete the installer will move to the next step automatically. From here you should follow the on screen prompts to complete the installation.
1helpful
CANOT GET FULL SCREEN ON MY LAPTOP
Makesure you have installed latest drivers.. Or try to change resolution from display property
2helpful
2answers
I can't install Print Shop Duluxe 22 with windows 7. What can I do to install this program?
The most important thing to keep in mind about installing Print Shop 22 on any computer is that Print Shop 22 requires that .NET Framework 1.1 be installed on the hard drive before Print Shop 22 is installed. (Print Shop cannot work with any other version of .NET Framework.) So, the first thing that the Print Shop 22 installation process will look for is whether or not .NET Framework 1.1 is installed. If .NET Framework 1.1 is not installed, it will be installed from the Print Shop 22 install disk before Print Shop 22 is installed.
32-bit version of Windows 7:
When a 'clean' install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 32-bit version of Windows 7, with two incidents.
1. The "Program Compatibility Assistant" in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 32-bit. To continue with the installation, select "Run Program".
2. At the end of the installation, this message will be displayed
The Amyuni Document Converter mentioned in that message is the Broderbund PDF Converter. This problem can be fixed by downloading and installing the Print Shop 22 Vista patch, which can be found here
I am looking for the Vista compatibility patch.
and which works equally well on Windows 7.
NOTE: Even though the information on that patch site says, "Note: This patch will only work for Vista 32-bit and not the Vista 64-bit operating system," I have confirmed that the patch works quite well on the 64-bit version of both Vista and Windows 7.
It should be noted, however, that when the patch fixes the problem with the Amyuni Document Converter, the Broderbund PDF Creator 3.0 will be installed - instead of the Broderbund PDF Converter, which was installed with WinXP and earlier versions of Windows. The Vista patch installs the Broderbund PDF Creator because the Broderbund PDF Converter is not compatible with either WinVista or Windows 7.
NOTE: One Windows 7 beta user has reported that his DVD drives disappeared after PS 22 was installed on Windows 7 beta 32-bit. This is a known problem with WinVista. So, it would be a very good idea to install the Vista patch BEFORE rebooting the computer.
If your DVD drives disappear after installing Print Shop 22, the only known solution is to uninstall Print Shop 22.
4helpful
I have a Xerox Phaser 3100MFP. It will print, but will not scan. Help...
have you installed scaner driver WIA SCAN DRIVER
and have you installed paperport v11
if not install paperport v11 and wia scan driver from"http://www.support.xerox.com/go/results.asp?Xtype=download&prodID=3100MFP&Xlang=en_IN&Xcntry=IND"
1helpful
2answers
Print Shop 21 will not work on Windows 7 operating system is there a fix?
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
1helpful
2answers
Print Shop 2.0 Deluxe will not load.
Have you tried installing them in Compatibility Mode? If not, look in
Vista's Help
& Support for how to try this. If that doesn't work, you can
try installing them as Administrator by right-clicking on the installer
executable and choosing "run as Administrator".
If none of that works, I'm sorry but you'll need to update to a current
version of the program that the mftr. says will work in Vista.
How to install logitech quickcam v11 1 on window vista. my cd does not work on my window vista
http://www.mydigitallife.info/2007/11/08/download-logitech-quickcam-version-115-to-expedite-high-quality-video-transmission/
here found some driver, also see the logitech site.
Sergio
Gear
the pleasure of owning a delicate exotica when there are no Guzzi shops within 100 miles your bike can't be moved and your friendly and competent Kawasaki shop is hardly Guzzi knowledgeable (and so am I it seems) ... smile.gif I have broken some transmission bearings and am now confronted (again) with equivalence problems... As you may know the Ghezzi STW is made off parts from V11 and parts from the 1100 Sport. From the picture below would you say it's a 1100 Sport transm' or a V11 trans' ? Yeah, I know, I know, but Bruno Saturno is on holidays and the entire Italian economics is at sleep in august. I have looked here and there are several threads wich mention parts number but as long as I'm not sure which bike donated the parts, I'm stuck smile.gif I have taken a V11 parts list and here's what i need bearing 26 (92 20 80 14 numbers are from a v11 2002 list parts) needle bearing 25 (92 23 40 55) spacer 04 35 51 02 (i actually need to measure it to be sure if it's 0,8, 0,9, 1 or 1,1mm) Are there equivalence between 1100 parts and V11 parts ? (the parts numbers aren't the same on the parts lists). Would you know any parts that would fit from a different origin (SKF ?). Thanx for any help..., well, I just looked in the sport 1100i workshopmanual, there they say replace each 15000km with sporty use or each 20.000 km with normal use. I know they live longer than that. But anyway it is good to take them of each 10.000km, have them in your hand and feel if they move without play. And while you have them there, it's the perfect moment to grease them. And I'm no saint either, I once had one with melted bearing cages. But that was the sort that didn't have grease nipples.,,,
Canot install photoshop in window vista
Check it out if the photoshop you are going to install on your Vista OS is mainly for Vista or XP Pro. If its not, then change it from where you bought it.
Top Broderbund Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
