Question about Toshiba 57H81 57" Rear Projection Television
Toshiba Picture bouncing... becoming horizontal line
I have a Toshiba TV that worked very well for 5+ years. A few months ago we noticed that the bottom of the picture would "bounce" up when we first started turned it on. After a while it would come back down and look "normal". It has gotten much worse over time though. Now when we first turn it on, the top and bottom of the picture have condensed into a single horizontal line going through the middle. We figured out that when we hit the bottom of the TV that the picture starts to "bounce" back. If we wait for the TV to warm up and hit it, we can usually get it to expand back to where it should be. Sometimes we have to do this several times before it "sticks" where it should be. Is this a fixable problem... is the set worth saving?
  • 767 Answers
Yes it sound like 1 or 2 bad solder joints.
It's an easy 15min fix for a good shop.
ask the shop if they could re solder it for 100.00
doesn't hurt to ask.
Posted on Jul 08, 2009
    Scholar:
  • 133 Answers
This sounds like a loose connection in the vertical circuit . The vertical IC would be the main suspect . These run somewhat warm and can the solder joints to expand and contract . Now what can also happen if you keep running it this way is the IC can become stressed out and finallly give out . Which will basicly give you one thin line side to side or some TV's when this part fails it will shut the tv down . Most shops depending if you can take it to them or if they have to make service the price will vary . Call around to a few local TV repair shops and get a rough estimate over the phone to what it might cost you . I would hope at best for a service it would not cost over $250.00 . Now if you can use a soldering iron you can save alot by soldering the loose connection yourself . Some experience would be required as some cabling straps would need to be loosened and plugs undone . Good luck and let me know how it turns out ( Team Tech )
Posted on Jun 26, 2009
Horizontal Green Lines On Screen. No Picture Visible. Problem is intermitent.
Are you certain of the connection? Sometimes the connector becomes loose or otherwise loses integrity. Maybe it's the cable (HDMI, right?)--or both the TV's connector and that. They may become worn.
Be careful with your LCD screen--they are more delicate than most people realize.....
Dec 16, 2013 | Toshiba Regza 52XV645U LCD TV
Toshiba rear projection TV 43VH9UA
have toshiba 43vh9ua picture is purple to blue in colour does anyone have a fix... thanks nev
May 12, 2009 | Toshiba 43H72 43" Rear Projection...
White horizontal dashed lines appear and at top of tv screen
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Mar 13, 2017 | Apex Digital GB43HD09 43" Rear Projection...
No picture only sound, Toshiba 36A 36" TV tube type
my friend if you open the tv carefully look to see if the tube itself has light, or if you have high voltage i coulbe many different things.wish luck!!
caypianan@yahoo.com
Aug 10, 2008 | Toshiba 36A50 36" TV
After a household power blips during bad weather, we have horizontal lines ....
Unfortunately there isn't any way to repair your tv as the magnet has distorted the tube that is in the tv and with CRT becoming obsolete the repair is likely to be very costly so probably your chaepest option is to buy a new tv .
Mar 13, 2008 | Televison & Video
Toshiba 36A50 Horizontal Line
Ok, The vertical Ic is IC301 Ta8427K And Capacitors around IC chroma 2.2 uf 50 volts. You will see small red capacitor ( with C302....4 or 5 ) reference. Replaced others capacitors on vertical section 220 uf 35 V or 100uf 35V. I hope this can help you. Or if do you have any picture chasis, send to me and I will show you where are the problem., Thank you
Dec 12, 2007 | Toshiba 36A50 36" TV
Red screen
sounds like a picture tube problem its a problem that probably cant be fixed only by a professional
Nov 30, 2007 | Sony KP-51HW40 51" Rear Projection...
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Is my Toshiba 57H81 worth repair?
Bounce horizontally usually means up and down,which relates
to the vertical output IC. Solder IC301, IC401 pin connects==try
again.You can easily isolate "bounce" problems by lightly
tapping on the vertical IC heatsink....Let me know if you need
further assistance.....T.
PS. Though hard to find, a qualified tech could do that repair
in home for 300. to 400.00...
Oct 20, 2007 | Toshiba 57H81 57" Rear Projection...
Toshiba 36A40 36" TV / Chassis No: TAC 0011
Bad capacitor in vertical circuit + possible vertical output IC
damage.If you can identify part locations and solder.....?
May 24, 2007 | Toshiba 36A40 36" TV
Toshiba 57H81 57" Rear Projection Television Logo
465 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
