Question about Samson Technology Zoom H4n Handy Recorder
Frozen it will power up but is frozen on a screen that says ver=1. 72 zoom
Same thing is happening to me ... did you ever get this resolved? Thanks in advance for your answer and help
Posted on Aug 01, 2016
My zoom g1x theres no sound.all power are working lcd light are on.but the sound cannot come out.can any one help me..
What letters / numbers that appears on the screen?
If the display is normal, and you can switch to other banks, and can edit each bank, then the problem of no sound, is at the pre-amp IC input, output amp, or CODEC converter.
This is the overall image of G1X inside.zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-0.jpg Next, we zoom-in the middle of picture above.
See the next picture.
IC2 (left) is input pre-amp IC (NJM2100).
IC4 (middle) is the CODEC IC (WM8734).
IC5 (right) is the IC output (NJU7082).zoom-g1x-theres-no-sound-all-power-2ss5ycyvkoajtv035dpuezke-2-1.jpg
Test whether the input IC is working normally, turn ON G1X, plug the guitar, go to BYPASS/TUNER menu. When the TUNER function could work, certainly input IC is not damaged.
Means only two possibilities, namely CODEC and output IC. That is not easily tested, except in specific ways.
May also, there are problems in the input / output socket.
Turn ON G1X. Try the following (see figure below):
  • Test the output socket. Touch pin output socket (right red arrow) with finger / screwdriver / whatever. If sound is heard in the amplifier, the output socket is normal.
  • Test the input socket, Same as above. (left red arrow). (if this happen in this point, problem is clear).
NOTES:
If lcd light are on (as you say), but appearing G1 or d5 or bt, and the system are hang / frozen, this is a different issue to the one described above,and dealt with in different ways too.
References IC datasheet:
NJM2100.
http://www.njr.com/semicon/PDF/NJM2100_E.pdf
NJU7082
http://www.datasheetarchive.com/dlmain/Datasheets-22/DSA-439015.pdf
WM8734 http://www.cirrus.com/en/pubs/proDatasheet/WM8734_v4.4.pdf
Sep 10, 2015 | Zoom Music
Zoom G9.2tt Gituar Effects Console
get ahold of these guys about repair to the unit, I checked through the manual and couldnt find anything of interest
http://www.zoom.co.jp/archive/English_Manual/E_G92tt.pdf
that might help you but doubt it.
Samson Technologies Corp.
45 Gilpin Avenue, Hauppauge, NY 11788
P.O.Box 18016, Hauppauge, NY 11788-8816
Tel: (1) 631-784-2200 Fax: (1) 631-784-2201
http://www.samsontech.com
E-mail: zoom@samsontech.com
if that dont work you can contact zoom directly at info@zoom.co.jp
Aug 11, 2008 | Zoom H4 Handy Recorder
Zoom b2 powers up with batteries, but not the power supply
Some possibilities:
  • Damaged on the DC-IN socket.
  • Broken solder joints on the center pin of the DC IN socket (see figure: -V). Resolder.
  • Damaged (broken) in D2 or R76. Replace
Jul 04, 2014 | Zoom B2 Bass Multi Effects Pedal
Zoom h1 handy recorder
Download the H1 driver for windows & try different usb cable........
Mar 09, 2017 | Music
It blinks with "be" and turns off
It may be "but" that you're seeing, which indicates the batteries are low. Use the AC adapter made just for this model only, and the guitar needs to be plugged in to turn the unit on. A full manual for this Zoom model can be found here:
https://www.zoom-na.com/sites/default/files/products/downloads/pdfs/E_G1_G1X_3.pdf
Dec 01, 2013 | Zoom Samson Technology Zoom G1XN Multi...
No power or display when I turn on the gadget, even using battery, it will display sometimes but a blink oh "be" letter appears on the screen
Zoom g1x dc supply not working, my zoom g1x is working when battery operated but if i connect it to a adaptor there is no power, i've already checked my adaptor and it was properly working, what can i...
Is the unit old?? Is it stored in an environment that has temperature fluctuations?? It could be the terminals on the input of the unit have dry jointed. This is when the solder lifts away from the circuit board. I have had the same problem on my ZOOM MRS1608 recording desk. Resolder the connections on the input. The base plate will problably remove easy enough to get to the point where the adapter is soldered onto the circuit board.
Good luck
Aug 11, 2011 | Zoom G1x Guitar Multi Effects Pedal with...
My Zoom h4 has been struggling for a couple months now. Most of the time I get either an error message concerning the card or saying the card is full. Even when the card has been reformatted both on my pc...
Make sure the batteries are good... some people try to use re-chargeable batteries and because of their lower voltage they cause problems. First thing is to try new batteries.
Feb 12, 2011 | Zoom H4 Handy Recorder
Zoom H4 recorder ver 1.30 says no card although card is inserted?
Hi. Not sure you still are in need of a solution but since my machine was doing the same thing last night, and I was able to solve it, I thought I'd post anyway.
For my machine, which has a more current OS than yours (mine is 2.20 I believe), I was receiving the same message after transferring material onto the computer. What needed to happen was to reformat the card. If you press "menu", the click on "file" you should have an option to reformat the card. It worked for me and it now works.
Hope that helps!
Sep 16, 2010 | Zoom H4 Handy Recorder
H4 zoom battery operation
try resoldering the circuit board where the power socket is ... as there is a switch on the socket that disconnects the batterys
Jul 02, 2009 | Zoom H4 Handy Recorder
Samson Technology Zoom H4n Handy Recorder Logo
78 people viewed this question
Top Samson Technology Music Experts
Are you a Samson Technology Music Expert? Answer questions, earn points and help others
