Question about Sterling Home
My Sterling toilet model 4515DB needs replacement parts can you tell me where do I get it?
Water leaking to the bowl
whytfang
  • 170 Answers
SOURCE: correct tank to bowl gasket for Orion toilet
I would change out the flush valve itself...it will come with the right gasket....it won't cost anywhere near the price of a new toilet...and it will save you time in the long run..good luck and.thanks for rating my effort....the fang.
Posted on May 01, 2009
  • 62 Answers
SOURCE: leaking under the rim of the toilet
Sound like what you are looking at is a corroded bolt that holds the tank onto the bowl. Remove and replace bolt and gasket with new part.
Posted on Jun 12, 2009
mckinley1945
SOURCE: Toilet Keeps running
try adjusting the floater valve >>bend brass rod down 1/4 inch untill you can not hear water comeing through
Posted on Jun 17, 2009
  • 10 Answers
SOURCE: Replaced toilet fill valve - now bowl water level a bit lower
put some water in with a bucket. poor some in slowly until you get it where you think it should have been. If it levels back out at the lower level. Then there is nothing wrong. Maybe the leaking water was keeping the bowl water line high than it should have been.
Posted on Jul 26, 2009
  • 17 Answers
SOURCE: toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Posted on Jan 23, 2010
How do I stop a small slow leak into bowl of 1 pc Crane toilet?
The seat where the flap sits could have a nick in it. The flap might not be aligned properly. A temporary fix is to put a small amount of Vaseline on the seat and that should stop the water leak.
Aug 30, 2014 | Home
We bought an elongated smooth sided Jacuzzi toilet and it is leaking clean water from the back toward the wall
Could be a few issue. First check at the back where the tank sits on the bowl, reach underneath or look with a flashlight if you can to see between the tank and the bow, pay attention to the bolts in particular, if you see any water dripping down the bolts or between the tank and the bowl, the tank to bowl gasket ir bowl gasket bolts are leaking, and need to be replaced. Also look inside the bowl when its flushing, no water should be splashing up over the edge of the tank. Also inspect underneath the fill valve that gasket could also be leaking, or the supply line could be leaking.
Jul 12, 2014 | Jacuzzi Home
Water leak from top drum area of washer
the top ring has small drain holes if blocked the water overflows the ring instaed of going into the bowl also if the machine is not level this can cause water to splash down the outside of the bowl
Nov 29, 2017 | LG WM2050CW 40 cu. ft. Washer
What would cause the water in the bowl to leak down to a little water left in bowl after flushing?
The float is stuck and the flapper leaks. Adjust the float so it won't touch anything, it needs to move up and down freely. Replace the flapper,
Sep 12, 2011 | AMERICAN STANDARD BOWL Elongated Bowl...
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
Leak under toilet bowl. Water seeps out from under the bowl. It's not a drip from outside .I replaced the wax ring but no improvement.
1 - Check bolts and washer from the tank to bowl for a leak.It can leak and run down the bowl and pool around bottom of bowl. It will run down the back and under toilet and come out from under bowl in front.
2 - Does the flange sit below floor level some wax ring's differ in size. May take a wax ring with a horn to in the flange, You may try 2 wax rings stacked or get a jumbo size one to get a better seal.
3-Check water line and for possible crack in toilet some where a last resort. Was the flange secure and in good shape, inspect it for a possible crack.
Jun 07, 2010 | Home
FLUSHMATE TOILET BOWL WON'T HOLD WATER
The Flushmate system won't cause or contribute to water draining or leaking from the bowl.
Negative back-pressure in your drain/waste/vent piping could be siphoning the water out or you may have a crack in the bottom of the bowl or trapway that's allowing the water to leak out.
If the floor under the toilet (actually underneath it) or around the edge where it's caulked to the floor is wet, your bowl may be cracked. If not, your plumbing system may be siphoning the water.
Either way, you can exclude the Flushmate from the equation and focus on the porcelain fixture and your drain/waste/vent system.
Hope this helps.
Jun 06, 2010 | Sloan M-101526-F Flushmate?® Complete...
Toilet bowl doesn't hold water but tank is full
The bowl is filled up with the little hose inside the tank, it locks inside of the overflow drain. And runs water in there as it flushes to swirl the water and fill the bowl. Water seeks it's own level, and the level in the bowl is at the top of the trap. It has to hold water, unless it isn't filling or it is leaking. Check out the filler and hope the bowl doesn't have a crack in it. Hope this helps.
May 03, 2010 | American Standard Home
I have a toilet that won't hold water in the bowl-it slowly just goes to none-checked under all the way to drain line no leaks??
You could have an inadequate or blocked vent which is allowing some other drain flow to **** the water out of the bowl (but you would hear it going glug glug) So, more likely, you have a cracked toilet bowl. If no water is leaking onto the floor it must be cracked in a way that allows the water to leak down the drain (by-passing the trap that is built into the back of the bowl). You will have to replace it. The good news is that replacing the bowl is far easier than fixing the vent problem.
But before you replace it, you can test it. Remove the whole toilet from the floor. Elevate it on some blocks over a bucket. Fill the bowl using another bucket and watch what happens.
Apr 01, 2010 | American Standard Plumbing
Water leaks when flushed between tank and bowl.
You have a large rubber washer between the tank and the bowl that may need to be replaced. It is around 3 or 4 inches in dia.You have to take the tank off the bowl to replace it. You can get it at any hardware.
Hope this helps
Sep 15, 2009 | Home
Home Logo
198 people viewed this question
Top Sterling Home Experts
jmartin50
Level 1 Expert
Tim Whalen
Are you a Sterling Home Expert? Answer questions, earn points and help others
