Question about GE Add-On Wireless Digital Color Camera 45256
Pair 45256T wireless color camera to my ZTEN800 cell phone
How do i simply deleted edit and contact on model zten800
open contact list then select name or number then select option follow the instructions there
Feb 18, 2015 | Cell Phones
Uniden survaillence system will not pair with this camera but says it will pair with any wireless camera. How do I pair the GE with Uniden
I am not aware that Uniden survellience systems pair with cameras other than a Uniden camera. Please provide model number of your Uniden system to help with a solution to your problem.
I understand that GE Add-On Wireless Digital Color Camera 45256 will work only with a GE security system like Ge 45255
Apr 27, 2014 | GE Add-On Wireless Digital Color Camera...
Connect wireless digital color camera 45256T to my tv
You need the receiver and then you can only view it from a computer.
Apr 24, 2014 | GE Add-On Wireless Digital Color Camera...
Pairing with I pad
You can't use bluetooth to pair other camera's or any other equipment with the iPad, unless it is approved with Apple. To view pictures from my DSLR, I use a Transcend WiFi card (Eye-fi and other brands have them to on WiFi) with a special app. But still this is on WiFi. The card works as a hotspot. For bluetooth you need special equipment. The manufacturer has to build in special protocols which he gets from Apple.
Nov 28, 2013 | GE Add-On Wireless Digital Color Camera...
Lg l I will not pair with plant tronics headset
hi sarzim take the battery out of the lg phone .. Once youtake the back off check to make sure the is no dirt or any foreign obstacle in the contacts . Next put the battery back in the hone. The next thing you want to do is go into the settings and go to wireless settings. Next go into bluetooth make sure is is in sidcoverable mode scan for devices. ON the plantorics make sure that bluetooth is flashing back and forth two colors. Once all this is done the phone and bluetooth should pair together.You need the pplantroincs blue tooth to have a good charge and the liightd flash back and forth it becomes one color when it is pair with the phone.the code is 0000.
Nov 26, 2010 | LG Ally Cell Phone
Parrot 3200ls bluetooth wont pair with phone
go to SETTING / PAIRED DEVICES / move onto a paired device and press the middle button , then scroll down to delete and press middle button, then press green to confirm.
Apr 08, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Can not pair the phone to parrot even after entering the code
try deleting all previous paired devices from the parrot menu then try again, if not let me know what phone you have and the software version of the parrot.
Mar 04, 2010 | Parrot Ck3200 Ls - Color Cell Interface...
Problems pairing my Just Wireless Blue BT-35K2
If you can get the headset into pairing mode, and your phone into detection mode and it's still not pairing, try removing the battery while powered on. Replace the battery and retry, and it should work.
Jun 26, 2009 | Cell Phones
Unable to pair with CK3100
You need to reset the Parrot first.
Hold down red and green buttons together until she tells you that the memory is being cleared. Then she will prompt you to pair your phone.
Feb 05, 2009 | Parrot Ck3200 Ls - Color Cell Interface...
Pairing Problem with Cell Phone and Bluetooth earpiece
Not all bluetooth headsets are compatible. These are:
BlueAnt Wireless X3 micro Bluetooth Headset.
BlueAnt Wireless V12 LCD Bluetooth Headset.
BlueAnt Wireless Z9 Bluetooth Headset.
http://www.yourwirelesssource.com/buy/accessories/cat/28/model/1005_300368/accessory/291758?source=google_base
Mar 28, 2008 | Cell Phones
GE Add-On Wireless Digital Color Camera 45256 Logo
61 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
