I can not duplex to my Ricoh 2238 c copier from my computer. i have vista windows
    Problem Solver:
  • 12 Answers
Make sure that the duplux option is enable on your windows print setting?
Posted on Jun 22, 2009
Installed a duplex unit in Ricoh CL 3000 not working.
You will have to find in printer driver ----> change accessories and you will have to CHECK duplex unit. Then you will be able to use the duplex.
Good luck
Sep 22, 2014 | Ricoh Office Equipment & Supplies
Setting the duplex printing for RICOH Aficio MP 3351
You just need to go to printing preferences and set the tab duplex. (Opens a tab and you chose which one you want.)
If you want to put duplex by default, go to:
Start - printers - click on the right on your mouse - properties - Printer preferences - and Change the duplex. In the end just click on "apply".
Feb 24, 2011 | Ricoh Aficio MP 161 Black and White Copier
MY Ricoh Aficio 2550 Printer I use it via IP in windows 7 and can't print Duplex Unit it said. Duplex :(Something conflict I can't Remember) Duplex: Unit not install
In Windows 7, you can right click on the printer under Devices and Printers, then select "Printer properties" (not "Properties"), then under "Device Settings" you can set the "Duplex Unit" to "Installed". Afterwards, you can go back to "Printing Preferences"->"Finishing"->"Print on Both Sides"->Print on Long/Short Edge.
Dec 28, 2010 | Ricoh Aficio CL7200 Laser Printer
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
How do we get this machine (ricoh aficio MP 2000) to duplex print?
There are certain models that can duplex and certain models that can't. Generally if a Ricoh copier can duplex it has a D after the name (like 2018D). If there is no option for duplexing on the screen or the ops panel, that model doesn't support duplexing.
Apr 30, 2010 | Ricoh Aficio MP 2000 Black and White...
How do you print via computer double side print automatically with duplex on a Ricoh 1232C copier printer.? (also know asc Aficio DSC, Gestetner R032C, Infotec)
First you need to enable the duplex option in the accessories tab.
Go to printers, and sellect properties(right click) and accessories.
Feb 25, 2010 | Ricoh Aficio 1232C Color Copier
Cant find the setting for double-sided printing on a Ricoh printer
Go to the start menu from the windows desktop then go to printers and faxes then when you will see the driver for the AP 3200 click the right click while the pointer is on the driver and then click properties from the drop menu, then go to accessories and see do the Duplex unit is selected but first see do you have the duplex unit on your printer you will easy notice by the picture when you will select the duplex unit.If you have the duplex unit on the printer then just select the duplex unit then click apply and then ok and now you can close the window. now when you will want to print duplex when you will click the print button from the word or PDF document go to properties and select that you want to print duplex
Jan 26, 2010 | Ricoh Aficio AP3200 Laser Printer
Networking at Ricoh 1035
does your 1035 have either a printer or printer /scanner option. If it does just hook s line up to the network connector on the back of the controller. hit user tools, system settings, interface settings, network settings and then select auto obtain. now exit from the user tools to the regular screen. wait about ten seconds to let the settings take effect. Now hit user tools , printer features, lists and hit configuration page. Take this page to the computers with you. Go to start, add a printer add a local printer, deselect auto detect, hit next. Now hit add port select tcp/ip from drop down button. in location where is it says printer name or ip address enter the printer name located on the bottom right section of the configuration page you printed. now go to ricohs website www.ricoh.com, americas, then at the top you will see downloads. then a screen will apper that says drivers and manuals. select black and white, 1035 and windows vista. create a folder on your desktop called printer. once in the folder, open it double click and unzip it into the same folder.now back to page after you have typed in the printer name and hit next. go to have disc, browse to the folder on the desktop and follow the prompts form set up, drivers, vista, pcl 5, english and the select if this is your default printer, do not select sharing and ask it to print a test page. once this has printed go to the properties tab on the drive itself and select accessories. and add whatever options your copier has ie. sorter, duplex or extra paper drawers. Now do this to all your copiers on the network. doing this allows you to print from any computer regardless if any other computer goes down
Dec 11, 2008 | Ricoh Aficio 1035 Copier
Problem with my ricoh 2238 printer
* 28 * - maintenance mode. you need to reset the oil counter in mode 5. somewhere there. can't remember the exact simulation number. It's the same mode as the fuser settings.
Jun 26, 2008 | Office Equipment & Supplies
Operation of Duplex through computers
Go to "start" then "printers and faxes" ( If XP). RIGHT click on your default printer ( Ricoh 2022) select properties, at the top of the screen you will see a tab that says Accesaries" hilight that tab and down on the page that says "duplex" place a check mark where it says duplex. CLICK APPLY or it will not change when you exit.
hope this helps.
gizard
Jun 26, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
k24674
jasbo
jasbo
Marvin
Marvin
