Question about Metrologic MS7820-118 - Honeywell Solaris Ms7820 Desktop Bar Code Reader - Dark Gray - Wired - Laser
Honeywell MS 7820-118 Drive - Metrologic MS7820-118 - Honeywell Solaris Ms7820 Desktop Bar Code Reader - Dark Gray - Wired - Laser
I forgot my menu password
Contact Honeywell tech support and ask them to email you the .bat files that will reset the log in info. Put it on a blank thumb drive, power down the unit, plug in the drive and power up the device. It should reset it back to the default user name password. If you don't know what they are make sure you get them from Honeywell.
Mar 23, 2014 | Honeywell HRDP16D500 16Channel DVR 500GB...
Tip
ERROR codes Canon 6650
Canon 6650 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E500 An error is identified in the communication between the sorter and the copier E510 The clock signal from the motor is absent for 250ms or more E510 Sorter motor drive E513 The clock signal from the motor is absent for 250 ms or more E530 Sorter home sensor E530 The home position sensor (P17) fails to go OFF when an equivalent of 2560 pulses of the motor drive command has been generated E531 The stapler unit swing sensor (MS9) fails to go ON within 500 ms after the motor drive command has been generated. MS9 fails to go back OFF within 1000 ms after it has gone on E531 Stapler swing sensor E540 The lead cam home position sensor (P12) fails to go OFF within 2000 ms after the motor drive command has been generated. P12 fails to go back ON within 2000 ms after it has gone OFF E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
Hi.....im using Eclipse Metrologic Instruments, model no.is MS5145 LS USB barcode scanner. now it is not working. whenever i tried to scan a barcode, it red light goes on continously. i also initialized it...
If the kit number : MK5145-71a48 that you referenced above is correct, your scanner is single ended keyboard wedge, not usb. You would need to order the correct cable : MX009-3ma7c from Honeywell to connect via usb.
Sep 14, 2011 | Metrologic Instruments Eclipse MS 5145...
I cant use my ms word,,,coz they had the reformat on this pc,after that,i cnt use my ms word
if your computers hard disk drive have been re-formatted then the ms word suite has been removed from the computer. you need to re-install ms word program.
Aug 22, 2011 | Computers & Internet
Has the IBM drive part number 32P0725 been replaced by another part number at all?
Drive Features Capacity: 146.8 GB Interface: Ultra320 SCSI Rotational Speed: 10000 rpm Access Time: 4.7 ms Type of Drive: Internal System Type: PC Average Latency: 3 ms Additional Features: Predictive Failure Analysis (PFA) Compliant Standards: CE, CSA, UL, TUV, C-Tick, BSMI
Sep 21, 2009 | IBM (32P0725) 146.8 GB Hard Drive
I just purchased Microsoft Home and Student 2007 and cannot install it beacause my CD Drive does not work. Can I install with product key?
Dear sir,
According to your problem solution is Copy content of the MS-OFFICE 2007 CD to a Pendrive(Thumb Drive) from other computer having working CD ROM.Then connect thumb drive to your computer install MS-OFFICE through Setup file present in the thumb drive,if it asks product key give the product key printed on MS OFFICE 2007 CD envelope. It solves your problem.
Good luck
Fixya Customer Support
chandrashekahr
Jul 29, 2009 | Microsoft Office Professional 2007 Full...
Make MS-DOS Boot CD
Hi. This adress (http://www.bootdisks.us/ms-dos/5/ms-dos-bootable-cd-images.html) contains a couple of ready boot discs. Just download them (.iso file) and burn them to a CD. Hope this helps.
May 22, 2009 | Microsoft MS Windows XP Professional SP2
Cannot find hard drive while installing MS XP on a hp nc6220 laptop.
hi
It used to happen like this during the new installation.
goto BIOS setup and check that the HDD is correctely detected. check the size it reported. If its correct, give one more try. else the HDD firmware is corrupted and can be repaired.
thank you
Aug 15, 2008 | Microsoft Windows XP Professional for PC
Installation of ms office regarding
Hello Sir/Madam,
First u copy the installation files of ur pen drive into your system. Then install it. The problem will be solved. ok
Thanks
"Don't Forget to rate the solution"
May 20, 2008 | Microsoft Office Professional 2007 Full...
MSI MS-6541 Motherboard drive
i need sound driver of mother board motherboard MS-6541 VER :1.0
May 09, 2008 | MSI MS-6547 Motherboard
Metrologic MS7820-118 - Honeywell Solaris Ms7820 Desktop Bar Code Reader - Dark Gray - Wired - Laser Logo
130 people viewed this question
Top Metrologic Computers & Internet Experts
David Payne
David Payne
Are you a Metrologic Computer and Internet Expert? Answer questions, earn points and help others
