Question about ViewSonic Pro8200 Projector
Viewsonic pro8200 shutdown - ViewSonic Pro8200 Projector
Relaced bulb, but still flashes green goes to white screen and searches for source and continues to do this
Do you have a source plugged into the projector ? This means a computer, laptop, Ipad, or dvd player ?
Jan 28, 2016 | ViewSonic Pro8200 Projector
How Do I Clean The Dust Out Of The Inside Of My Projector?
Most models are very similar. Here is a video of a similar repair. Be sure to take lots of pictures as you go if you give it a try.
Jul 13, 2014 | ViewSonic Pro8200 Projector
Lamp not firing but sound works
If all other parts of the projector seem to be working, but no light come from your projector. It may be time to replace the bulb in your machine. There may be other issues with your projector but more often than not, it is time to replace the bulb.
Here's a helpful guide : http://www.ebay.com/gds/A-Step-by-Step-Guide-to-Replacing-Projector-Lamps-/10000000177628964/g.html
Mar 12, 2014 | ViewSonic Pro8200 Projector
PJD 5111 Viewsonic projector shuts down after 10minutes?
Hi! I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 20, 2011 | ViewSonic PJD5111 Projector
What does it mean when the ViewSonic VG900b light turns from green to yellow?
It can mean it is not getting the video signal from the video card, bad VGA cable, or it is in safety shutdown mode. Try it with another PC first. If it still does not work then you will need to troubelshoot it. Read my guides and see the picturesd of failed VIEWSONIC and all other brands mostly due to bad caps.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 25, 2010 | ViewSonic VG900b 19" LCD Monitor
I have set the auto shutdown to maximum, however, the projector keeps shutting after 20 minutes. What is causing this?
Check to make sure that the auto shutdown is turned off. This should prevent any further problems.
Aug 04, 2009 | ViewSonic PJ506D DLP Projector
Viewsonic VA1930WM - Dead
Inside the monitor there are two backlight tubes about 8inches long and the thickness of a pencil. A fall could easily have broken the backlights. Probably should take it in for repair.
Dec 29, 2008 | ViewSonic VA1930WM LCD Monitor
ViewSonic Pro8200 Projector Logo
146 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
