Maytag Bravox washing machine once set to cycle lid lock comes on then goes off immediately and only the wash light is lit up without washing the clothes
5 Suggested Answers
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
  • 107 Answers
SOURCE: My clothe come out very wet at the end of the wash cycle
If the pump is clogged and can't release all the water it won't go into final high spin. Remove lower cover and locate coin catch and unscrew it. Water will come out, so be ready. If it's full of stuff, this is probably the problem.
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Posted on Jan 08, 2011
My Maytag Bravos washer. MVWXG655Dw0 doesn't complete the cycles and the wash light comes back on
Is lid locking? If not, lid lock should be replaced. If so, most problems I have found from that model comes from shift actuator under machine that shifts transmission from agitate to spin. Also be sure drain Pump is working and pumping water.
Sep 13, 2017 | Maytag Washing Machines
Lid locked light on, will not release
The lid lock light won't stop blinking. - Fixya
www.fixya.com/.../t14714916-lid_lock_light_won_39_t_stop_blinking
Oct 21, 2012 - The lid locked keeps blinking and I can not start a cycle. - WhirlpoolLSB6200KQ Top Load Washer question. ... Whirpool cabrio wtw5500xw top loadwasher will not start lid light flashes then goes out and into flashing pause ...
Whirlpool washing machine_ lock light flashing_ nothing ...
? 1:53
www.youtube.com/watch?v=zrV9w6Z5LAU
Mar 3, 2012 - Uploaded by briantaylor62 Whirlpool washer wont start a cycle, lid does lock and the locklight ... a cabrio as well that just has the lid lock flashing and nothing happens , I ...
Flashing Lid Lock Light: How to Troubleshoot Errors on Your ...
? 1:23
www.youtube.com/watch?v=nttHsAX2_OM
Mar 27, 2015 - Uploaded by searspartsdirect
The lid lock light on VMW washers, made by Whirlpool, Kenmore and Maytag, will flash whenever there is a ...
Oct 12, 2015 | Washing Machines
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Mar 23, 2015 | Maytag Washing Machines
Maytag centennial washer
When lid lock flashes, that is an indication of a bad lid lock in some of the mvw washers.(depending on your unit and model number &error codes)
Nov 03, 2013 | Washing Machines
Fisher and Paykel GW512 wont complete spin step.
This the lid lock device
If lid is open circuit, one of the wires have came off the plug.
Jul 19, 2012 | Fisher and Paykel Washing Machines
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
May 30, 2012 | Maytag Washing Machines
Our Maytag Bravos washing machine will not unlock. The lock light is not lit up. We ran a load twice and it still did not unlock.
du is the code for cannot unlock,,,,is there excessive weight on the lid, such as a basket of laundry? Excessive weight will keep the lid from unlocking. Press POWER/CANCEL once to clear the code.....
Dec 11, 2008 | Maytag Bravos 4.5 Cu. Ft. Washer
Washing Machines Logo
Top Washing Machines Experts
