Question about Bosch Washing Machines
Washing machine jumping program
Washing program jumps from 12 minutes down to 1 minute then stops atogether
dauphine
  • 207 Answers
SOURCE: my machine wont go passed the wash cycle
Machine awaits for water temperature to rise but it never happens and that's why it "wont stop it just keeps going and going". It happens because the water heater is either dead or one of the two cables powering it are corroded or have fallen off from heater.
If you're experienced DIY guy than need to check if the both cables are properly attached if so than you need to test if the current goes trough the heater. If not than it needs to be replaced. If you're not DIY than call the repairman since messing with it can be dangerous.
Posted on Apr 11, 2008
SOURCE: loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Posted on Sep 17, 2008
canbruce75
  • 1776 Answers
SOURCE: After 27 minutes into wash get an FH error
The FH code on the Whirlpool Duet washers indicates that the unit is not detecting water fill at the flowmeter. The flowmeter is sits right in front of the water inlet valve and is attached via a hose and is off to the left of the central control unit (ccu). If the washer seems to be filling alright, check out the wiring from the flowmeter to the control unit. Make sure all connections are clean and tight. These connections have been known to jiggle loose and cause this code. Hope this helped and best wishes.
Posted on Aug 02, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine is jumping around on the spin cycle
A few possibilities here.
Make sure the washer is level, both back to front, and side to side.
Do not over load, and make sure that there is more than 1 article in it, otherwise you will get an out of balance load.
Make sure the water is drainlng away properly.
Check the drum for excess movement, this would indicate a broken spring or worn drum bearings or worn or broken drum shaft.
Check the concrete wieghts at the top and bottom are not loose or broken.
Check the suspensions for excessive wear.
Hope this helps
Posted on Mar 31, 2010
  • 744 Answers
SOURCE: In the Spin cycle, after 9 minuts, it will stop with a "UL".
"UL" means "Unbalanced Load" - make sure the washer isn't overloaded first or if you are doing rugs, blankets, or lots of jeans, split the load. You can also try running an empty or light load and see how the machine behaves.
If you still have the problem, you may have some issues with the drum bumpers, etc., but try the easy things first.
Posted on Jul 12, 2010
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
The washer goes to LE and flashes. Then the washer stops.
Could be 1 of 2 things your washer nds a reset try unplugging the washer leave unplugged for 5 minutes replug start your machine Your drum may be out of line when it starts to wash it jumps off if that's it u will nd to call 4 service
Apr 22, 2013 | Washing Machines
Our Bosch Maxx 7 skips spin cycle of the washing program. The remaining time jump from about 7 minutes to 2 minutes
Possible that the program controller unit has some errors and so it does work erratically. Check on all connections to the program controller unit, check for moisture on the unit. Also remove power for few hours and see if there is any change.click on : washing machine tips
Mar 14, 2012 | Bosch Washing Machines
Jul 12, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Timer Jumps
Hi. The time displayed at the start of the program is an estimated time to complete the cycle. The appliance will calculate the wash time base on load size, water pressure, water temp ect. If a smaller load is to be washed then less water will be required thus shortening the time required to fill and heat water as a result this will reduce the wash time. EG. The more water you put in your kettle the longer it takes to boil.
Jan 01, 2010 | Miele W2240 Front Load Washer
Jumps time on timed cycles- for example: High dry is 40 minutes time goes down to 36 minutes and then is jumps down to 23 minutes. Once it goes down some it might jump back up during the 20's then it goes...
Replace the timer, this is very easy. Un plug, remove access panel in the back and un plug the timer. This will be connected right behind the knob. It will be screwed down in front as well. Call your local dealership and get replacement part.
Jul 26, 2009 | Whirlpool WFW9200S Front Load Washer
Timer won't count down
service bulletin says the washer times can do that as the washer senses variables changing and all times are estimations and its normal .if the washer detects failure it will set a trouble code hope that helps
Dec 30, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
10 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
