Question about Honeywell Heating & Cooling
Vysa therm 2500
Always on
Maytag DE810 Dryer takes too long to dry
Have you checked the Hose and the pipe that exits your wall? Sometimes birds will nest in them. Pull the dryer out and run it without the hose connected to test it.
May 18, 2015 | Dryers
OVERHEATING ON 91 BLAZER
You would have air pockets with a new thermostat and none if you leave it out.
Are you sure you are burping the cooling system with the new thermostat installed ?
Its also possible you have a leaking head gasket or other problem that is being amplified by having the thermostat installed. Something may be heating up with and not without.
Mar 04, 2013 | Cars & Trucks
Tempra 36 luke warm
turn thermostat up, if that doesnt do it, replace therm.
Dec 20, 2012 | STIEBEL ELTRON TEMPRA 36 Tankless Water...
New digital therm. air works but no furnace can be found on therm.
What make and model of AC, as well as Make, model of thermostat ? Need that info for proper diagram.
Sep 13, 2012 | Dometic Rooftop RV Air Conditioner
My wife says that she was using the kitchen timer and everything went dead. no lights, no nothing. Any suggestions?
cavity therm is bad probably, some people use the micro as a timer thinking they are using the kitchen timer and it burns out the cavity therm. get a qualified svc company to replace the therm, if it is the therm it wont heat or start or anything, if its just the timer thats not working then i suggest a new clock board.
Sep 04, 2009 | Microwave Ovens
AC won't run on low speed
It may not be wired for low & high fan mode. If it always did before, then yes there's a problem.
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
1999 Chevy No Heat, and Overheating.
did it over heat before the therm? if not it is the wrong therm. Other than that you have to have a air pocket.
Feb 13, 2009 | 1999 Chevrolet Silverado 2500
Heating & Cooling Logo
41 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
