Question about AEG Lavamat 16810 Front Load Washer/Dryer
Drying cycle not lasting long enough - AEG Lavamat 16810 Front Load Washer/Dryer
Water coming from under appliance
Maybe your dryer is not drying!!!!!!!! Is it getting hot? Heat element ok? Maybe the washer is not doing a good enough job during the spin cycle and leaving clothing excessively wet.
Sep 08, 2017 | Refrigerators
Whirlpool gas dryer will not gethot enough to dry
the usual problem is lint build up and or to long of a run for the exhaust tube..When was the last time you cleaned you dryer exhaust ? I had an issue where I had to run my dryer through 4 cycles before a load would get close to being dry. I thought I has cleaned out all the lint from the dryer.. Finally I just ripped out all my exhaust tunes and sure enough there was a a large amount of lint build up where the shop vac did not reach. SO i replaced all the exhaust tubing and since I have a long run I added an exhaust fan, now the dryere works like it should,..
Apr 29, 2014 | Frigidaire Dryers
Viking dishwasher VUD040 keeps tripping the circuit breaker during drying cycle
Are you sure the breaker is big enough to carry the Amps needed to start the drying cycle. You know that due to inductance it takes almost twice as many amps to start a motor as it does to run it.Find out how many Watts it uses and divide it by 120VAC and it will give the maximum amps it will draw. See if the breaker is high enough amp for it. A 25 Amp breaker should be efficient. I hope this helps you and if I can help you in anyway in the future let me know.
Mar 12, 2014 | Viking Dishwashers
Doesn't dry clothes in spin cycle- spins but not enough
so it is the spin cycle that does not work that is the drum does not turn. Have you tried other levels such as delicate wash and see if spin works. LASTLY, disconnect power and reconnect.
Mar 03, 2014 | Frigidaire ATF6000ES Front Load Washer
Drier not hot enough when i set temperature to high position
Replace the high limit thermostat located on the top of the heating element housing. Here is the part to order.
Nov 18, 2012 | Frigidaire GLER104FSS Gallery Series 27...
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Not enough heat
You may need to adjust the air flow on your dryer vent.
When an LG dryer is functioning normally---the time required to dry laundry is determined by the *Sensor* located on the drum side of the lint filter housing and by the main control board.
When laundry is near dry--any Time Remaining on the control panel that is *not* needed will be eliminated---except for the last 6 minutes.
The final 6 minutes of any LG automatic cycle is for cooling down the laundry before the dryer ends the cycle.
If a dryer *counts down* to the last 6 minutes but the laundry is still not dry--the computer will allow the dryer to run until the laundry has dried or defaults (not drying within the additional time allowed).
Dryer vents that are longer than 8 feet with more than (2) 90 degree turns--can affect drying performance.
Setting the DRY LEVEL selector to *Very Dry* will solve most dryability issues. In homes with abnormally long vents--even the longer run time in the *Very Dry* setting is usually not sufficient to dry laundry loads.
Reducing the length of the vent or starting a second cycle becomes necessary to fully dry the clothing.
If a second cycle was started---only the amount of time that is needed to dry laundry will be used before dropping to 6 minutes and then the cycle will end with dry laundry.
LG gas dryers are more sensitive to venting length and air flow resistance. The gas burner can cause a rapid increase in temperature compared to an electric burner.
Rapid temperature rise in a gas dryer leads to premature burner shutdown (longer time required to dry laundry).
The gradual temperature increase of an electric element is more "forgiving" in homes where the dryer venting is less than ideal.
Problem:
The dryer has an auto dry feature which never fully dries the clothes so we wind up manually setting the dry time to an hour
Solution:
LG gas dryers are VERY temperamental in long vent set-ups. If fabric softener sheets are used in the dryer--clean the two stainless steel strips of metal on the lint filter housing with a SCOTCHBRITE PAD--scrub back & forth several times to remove the waxy residue from the fabric softener sheets. Most,if not all manufacturers do *not* recommend using sheets in dryers that have a moisture sensor (electrodes).
However--using a SCOTCHBRITE pad keeps the wax off those sensors which can be seen if looking *into* the dryer drum and at the lint filter housing.
If only *liquid* fabric softener is used in the washer--clean the dryer sensors once a month. Liquid softener also contains wax which can slowly accumulate on the dryer sensors from the laundry washed in the washer.
LG DRYER SERVICE MANUAL
LG PARTS
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 11, 2010 | LG DLG5988 Stainless Steel Gas Dryer
Not drying enough
usually not drying enough, follows the statement long dry times, 2 or 3 cycles to complete the dry,
inspect your vent exhaust, and the entire length of the vent
you may have some sort of restrcction slowing down the exhaust which will cause heavy cycles,
the heat backs up inot the machine, and causes false high heat
Oct 18, 2009 | Kenmore 98702 Stacked Washer/Dryer
Most of the time it takes two cycles to get load dry
Sounds like an intermittent fault on the heating coil (or possible intermittent pilot failure). Or thermostat out of calibration (but I doubt that last one is likely)
This fault sounds a bit dodgy and I'd recommend getting a qualified appliance serviceperson to troubleshoot this.
May 10, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
IT IS STUCK , IT JUST HUMMS ,CYCLE DOES NOT START
I PULLED THE DISHWASHER OUT FROM UNDER MY KITCHEN TOP. THEN TRIED IT AGAIN AND IT STARTED WORKING. WATER WAS ENTERING THE MACHINE AS IT SHOULD AND THE WHOLE CYCLE WAS COMPLETED FROM WASHING TO DRYING. BUT WITH THE ODD RATTLING SOUND NOT COOMING FROM DISHES. I ASSUME THE INLET PIPE WAS PROBABLY BENT THEREFORE BLOCKING WATER COMING IN BUT WHY NOW AFTER YEARS OF BEING IN THAT POSITION. THE OTHER THING I CHANGED WAS THE ELECTRIC SOCKET POINT- IE I PLUGGED IT IN SOMEWHERE ELSE BECAUSE MOVING IT MEANT THE LEAD COULD NOT REACH ORIGINAL SOCKET. HOPEFULLY WHEN I RETURN IT TO ORIGINAL POSITION EVERYTHING WILL BE WORKING. FUNNY THING HAPPENED THE WEEK BEFORE- MY WASHING MACHINE WAS STUCK IN MIDDLE OF A CYCLE . BUT STARTED WORKING THE FOLLOWING DAY. COULD IT BE MY ELECTRICITY PERHAPS - IE MY APPLIANCES ARE NOT RECEIVING ENOUGH CURRENT?
Dec 04, 2008 | Dishwashers
AEG Lavamat 16810 Front Load Washer/Dryer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
