Question about Grohe ladylux faucet 33757
Replace thermostatic valve on grohtherm 1000 - Grohe ladylux faucet 33757
2 Suggested Answers
pipesster
  • 20 Answers
SOURCE: Grohe valve Grohtherm Thermostatic Rough 34-126
The thermostatic stop is set too low. Havent set a grohe before but most other thermostatic shower valves work similar. pull off the handle(however a grohe handle comes off . . ) there should be a notched ring or stop which keeps the handle from going all the way hot. pull out the ring and turn it a few teeth hotter put back and reinstall handle try water temp and adjust again if necessary.
Posted on Jan 25, 2010
I have what appears to be a Grohtherm in the shower in my new house and the water does not get hot enough. I have it set at 110 and it is on the verge of being to cold to take a shower. How do I fix...
unount the cartridge and clean it, probably there is some sand in it.
if that wont work uoy must trade the thermostat, if stillis in garantee good, if not that will expensive.
good work.
Feb 15, 2011 | Grohe Grohtherm Thermostatic Rough-In...
I cannot get any hot water to come out. ihave done everything except take out the cartridge.
that valve has a shut off built in...
flat head screwdriver, turn it so it is horizontal.
if that is already on, you might have a blockage inside the valve
Aug 15, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Where is the thermostat in my '05 trailblazer? The check engine light is on and the code is for the coolant system so I changed out the coolant temp. sensor and it is still on so i want to check the...
The thermostat is located on the drivers side of the engine block under the intake manifold. Is the code a p0128 thermostat regulating temp code coming on if so the thermostat should fix it.
Feb 22, 2010 | Grohe Grohtherm Thermostatic Rough-In...
I need to clean the filter on my grohe shower how do I do this
Use a flat head screw driver and unsrew the brass fitting remove the temperature spindel and wash out. Re install the same way and test.
Feb 19, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Grohe valve Grohtherm Thermostatic Rough 34-126 I turn the mixer to full hot but the temperature remains tepid. All the other faucets in the
Jan 23, 2010 | Grohe Grohtherm Thermostatic Rough-In...
Hot water not as hot from rain head as other outlets
i'm quite sure you shower valve has an adjustment on handle that allows more hot water into the mix,........it will tell you how in the paper work that came with the valve,....good luck, cracklin joe
Jan 06, 2010 | Grohe Grohtherm Thermostatic Rough-In...
HOW TO ADJUST A MODEL 34122 gROHE VALVE
there should be a flat head screw on the mixing valve turn the water on and turn it to the desired temp,, it is letting to much cold water in , if this does not work replace the mising valve
Apr 11, 2009 | Grohe Grohtherm Thermostatic Rough-In...
Plumbing Logo
Top Grohe Plumbing Experts
Donni Steen
john h
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
