Question about Whirlpool Refrigerators
Water drops come inside the whirlpool mastermind refrigerator every 4 hours
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
Please check if door gaskets are sealing properly
Posted on Jun 08, 2014
SOURCE: water inside chefmate refrigerator
Moisture inside the 'fridge condenses on the coolest parts. Most are designed so that the moisture runs down into a channel and is directed out through a small tube somewhere at the back of the compartment, near the bottom.
I would guess that the tube is blocked near the top.
Try finding the tube and carefully inserting something flexible down it to clear the blockage. Don't use anything too rigid, or anything metallic, as these may damage the tube and cause more serious problems. I have done this before using a pipe cleaner.
Posted on Jun 06, 2008
SOURCE: Water inside the refrigerator
is water in the bottom half of the refrgerator thanks
Posted on Oct 12, 2008
  • 236 Answers
SOURCE: whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Posted on Apr 09, 2009
SOURCE: WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
Posted on Jun 09, 2009
MARCLAVORIS
  • 110 Answers
SOURCE: Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
Posted on Nov 11, 2009
Whirlpool Mastermind 30Elite fridge giving continuous long beep sound with all the lights fastice,supercool,auto cool are on. Started it many times giving hours / day gap, but its not getting started.
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 01, 2017 | Whirlpool Refrigerators
What should be the cost of a door whilpool mastermind coloured refrigerator after 2 years of which actual price was Rs.19500.00 ?
I think you meant $1950.00 The unit in my opinion is worth maybe four hundred bucks or so. That would also depend on the appearance and also the quiet smooth operation of the refridgeration.
Apr 30, 2014 | Whirlpool Mastermind
Do they drain away down the back? It is probably just an automatic defrost cycle. check the stock temperature is ok
Apr 19, 2014 | Whirlpool Mastermind
Whirlpool mastermind refrigerator excess cooling
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at Whirlpool_Digital@Whirlpool.com with your name, address, phone number and the model & serial numbers of the Refrigerator.
Dec 26, 2013 | Whirlpool Mastermind
Continuous beep sound on start
the total set swict of the device and and start the ofter 2 hours
Oct 26, 2012 | Whirlpool Mastermind
I have a whirlpool mastermind refrigerator. from last 15 days water accumulates under the vegetable tub. why?
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 20, 2010 | Whirlpool Refrigerators
Whirlpool Ice Machine not working
Your water filter may need replacing.Also check where the water line is connected to water line under the sink,the valve there may be clogged up or need a new one.
Jul 20, 2017 | Whirlpool Gold White-on-White 21.9 cu. ft....
Sound of Water coming from internal backside of freeze
Your unit was in defrost mode (happens once a day) and ice that built up over the previous 24 hours was melting and draining down a drain line to a pan under the unit so it will evaporate. This is how freezers stay " Frost free ". The water in the pan under the unit will evaporate by itself. Have a great day!
barneyluc
Oct 10, 2008 | Whirlpool ARG930 Compact Refrigerator
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
