Frigidaire Electrolux front load washer no lights or sighn of being on it is getting power to the control board but not sure if its making it through what should I check
  • 173 Answers
Check the power to the bord with a tester
Posted on Apr 20, 2014
  • 145 Answers
SOURCE: Washer will not spin, pump will not empty nor fill
Don't have resistance for wax motor. It works or it doesn't. If the door locks with 120 volts to the wax motor it is working. From your checks you have the tech sheet out of the unit so I won't go take mine apart. Check the voltage fro the timer pins that the trouble shooting says to check. Also check the pressure switch. If it reads full it will not put power to the spin. That's not in the tech sheet.
Posted on Apr 24, 2008
localwonder
  • 6784 Answers
SOURCE: LG Washer wont start, no power
Make sure there's power getting to the washer. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the washer, if this is the case, the wiring must be repaired or replaced.
Posted on Jun 21, 2009
  • 3 Answers
SOURCE: Front Load Frigidaire Won't Spin Out
I had the same problem listed above on my LTF2140ES3...the machine did everything but do a final spin. In diagnostics I could do the final spin and the machine kicked out an E43 which is the control board error.
Following the advice here I changed the door latch first and the problem went away and the unit runs as it should.
You'll get "experts" who say that the unit would not spin at all if the door latch was bad. I can tell you first hand that they are wrong. Again the unit did all the normal tumbling but didn't do the high speed final spin. Again, replacing the door latch fixed the problem. The door latch is part number 131763245 (AP3886713)
Posted on Jul 21, 2009
SOURCE: my front load Electrolux washer asks me "clean
You do not need to clean a drain pump. After you have washes so many loads of clothes, soap scum builds up in your tub and will shorten the life of your product. You just need to run it thru the "clean" cycle. You can use 1/2 cup of bleach and NO detergent or you can by a tub cleaner from most grocery stores or Walmart and use that. It'll just remove any soap scum and mineral build-up off your tub. It should be done each time you washer tells you to do it. Hope this helps. :)
Posted on Sep 22, 2011
fernie_elazt
SOURCE: My Frigidaire gallery front load washer won't spin or drain
its ether the transmission or the motor gone bad
Posted on Jun 29, 2012
Frigidaire front load washer LTF2140FS2 stops after every cycle and the start light blinks
Good Afternoon Nicole, thank you for allowing me to assist you!
Typically, the Start light flashing indicates that the cycle has paused or the door is not securely latched. If the hose is not clogged and the door is closing properly, then more than likely your washer is experiencing a communication problem with the control board or wiring issue. At this point, I would strongly recommend contacting a professional to make the necessary repairs.
Best of luck!
Feb 09, 2014 | Frigidaire FTF2140FS Front Load Washer /...
I have a Frigidaire (ATF6000ES) Front Load Washer all lights come on and wont work.
Sounds like either the control board is faulty or the door latch sensor is not allowing the control board to communicate to the rest of the unit.
Aug 23, 2012 | Frigidaire ATF6000ES Front Load Washer
The washing machine Electrolux AURUM16 Problem
Make sure the water is drained or the door wont open
Sep 08, 2017 | Electrolux AWF1220 Front Load Washer
Frigidaire front load dryer won't turn on at all
check the main power and terminal block make sure there is power and no problems with the terminal block.
also a bad thermal fuse can cause a problem with the power check the thermal fuse and make sure they have continuity.the last thing to look at is the main control board these can cost up 150.00 dollars depending on where you get it.Bottm line yes i would say it is worth fixing
Jul 27, 2010 | Frigidaire Electric Dryer
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
TROUBLESHOOTING KENMORE ELITE HE3T FRONTLOAD WASHER WITH THE ERROR CODE F70
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2009 | Kenmore Washing Machines
My frigidaire front loader just stopped working... all of the lights went out, now nothing works
First off make sure your plug is getting electricity from its source, very seldom a washer stops working "completely".
If the breaker is fine and you are getting electricity to the board then chances are your main board is burnt www.laundryroomadvice.com
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Affinity front loader ATF7000FGO E23 ERROR
E23 error code means the drain pump relay on the control board failed or wire off pump. You already replaced control board so check the wire at the pump and make sure it's secure.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Webster/134879700.pdf
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire Gallery FWT449GFS1 washing machine
http://www.repairclinic.com/referral.asp?R=154&N=1094128
The internal brush can be used to replace brush in similar holder on certain Electrolux, Frigidaire, and Kenmore washers (at least motor # 131276200).
Dec 08, 2007 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
