Question about Sanyo Heating & Cooling
Green light blinking, not cooling - Sanyo Heating & Cooling
An Optoma GT750-XL ,
GREEN BLINKING LIGHT stand for power on warming or power off cooling.
Dec 13, 2014 | Optoma GT750-XL - DLP projector - 3D 60403...
Samsung AQV24NSGN red and green light blink
The blinks are a code. If 3 red blinks, could be power board.
Apr 13, 2014 | Heating & Cooling
Green power light want stop blinking
Problem is with one of the circut boards in the tv, It will have to be replaced.
Oct 21, 2012 | Sanyo DP19647 19 in. LCD TV
Toyota corolla 2003 air conditioning green light blinking and cold air not blowing
You've figured out by now the blinking light means the system has a problem. You'll need to find out if the system is low on freon or if a relay or electrical part is failing. The cooling fan could also be failing to come on, which would make the high side pressure exceed the limit and shut down the system.
Jun 24, 2012 | 2003 Toyota Corolla
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
Just bought a home with a Honewell trol atemp universal mini zone
because it dosent have a duct sensor - should not be a problem
Sep 03, 2009 | Honeywell Electronic Programmable...
Turned on TV and had no picture. Now when I reset I get green blinking light then solid green status. After about 30 seconded red lamp light comes on. Is there a solution?
Your lamp is defective, incorrectly installed, or the cooling fan under the lamp is not cooling the lamp for some reason. Service that area.
Jun 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Heating & Cooling Logo
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
