Question about Bosch HBL 745 Stainless Steel Electric Single Oven
Code E011 - Key pressed too long code on screen
My oven has stopped working and the code on the display is E011; Key Pressed Too Long. How do I fix this
What does E011 on the display mean and how do I clear it?
how can we guess as we have no MAKE /model to look for
Sep 17, 2016 | Ovens
How I can fix the Message
Depending on the make of the oven the error code E011 can indicate a faulty temperature sensor or bad control panel when steam escapes from the oven and into the panel. In either case this issue usually requires a repair technician to fix the problem.
Dec 23, 2014 | Ovens
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
I was self cleaning mt oven and now it stays locked , and displays a code of e1 in red on left side of display and f 5 on right side of display whirlpool self cleaning oven with accubake system
I pressed the start button for 5 seconds and the lock symble came on than I pressed the start button again for 5 seconds and the oven unlocked and all is well
Jan 07, 2010 | Whirlpool Ovens
Hi. My oven displays F7 in red and next to that
HI. This f-7 is indicating that the touch pad is malfunctioning. Follow the procedure below to address further.
Determine if the problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE( If your unit is equipped with an integrated touch pad, and control board, you will need to replace the entire control board in this case)
Nov 02, 2009 | GE Ovens
GE Single Ovwn control panel is indicating an F7 display model # JKP15WOA2WW
Fix the probelm, don't replace it with another of the same problem. Try this, it's gonna work! First of all, turn off the circuit breaker. Don't replace anything. The insulation in the ribbon cable is poor. The conductors in the cable are crossed. The ribbon cable is actually two ribbons pressed together, and the conductors between the two cables are shorting or becomming crossed. Lift the two cables apart, place a piece of paper between them, fold the edges of the paper over the cable so that it does not slip out, and make sure to shove it all the way down to where it will meet the plastic display panel housing. Turn the breaker back on. There, problem solved.
Aug 05, 2009 | GE JKP15 Electric Single Oven
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
JennAir 27
try unplugging the range for 30 seconds and see if it resets
Apr 01, 2008 | Ovens
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Display 11
your control must be fried...dacor fault codes are f0 to F8 the display must be faulty..
Aug 25, 2007 | Dacor ECD230 Epicure Electric Double Oven
Bosch HBL 745 Stainless Steel Electric Single Oven Logo
35 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
