Question about Standard Changer Equipment Standard MC520RL-DA Bill to Coin Changer Rear Load for Change or Toke
Remove coin acceptor
How to remove coin acceptor mechanism to clear jam
Coins fall right on thru and won't register any credits on both coin slots
check coin box is not full
check cables to coin acceptor are plugged in
Dec 11, 2016 | Washing Machines
Coinco 9370s coin acceptor power not staying on in pop machine.
Does it trip or stay on only waiting of wen you need to get coins
Sep 28, 2016 | Washing Machines
Need to know how to change prices on Toms Model H-22 Vending machine?
You change the price inside the coin mechanism. Tilt the coin acceptor (top part) down to see the price switches inside. Switch one is .05 and each switch to the right of #1 doubles in value. Turn on the switches that add up to the price you want and then test the machine.
Feb 10, 2015 | Retail Supplies
Can I bypass the neutral line going to a coin acceptor in a Maytag washing maching?
sounds like you can't be out much if you try it and it doesn't work
Dec 18, 2014 | Maytag Washing Machines
Change the price on maytag top loading washer
Price change for a model MAT12.
Remove the access plate above the coin acceptor with a key. The display should show code 6 and two numbers. Code 6 is the regular cycle and the number of coins required to start. Press the perm press button to advance the number of coins. 06 equals 6 quarters, 08 equals 8 quarters, etc.
Reinstall the access door when finished.
Stephen
Feb 19, 2012 | Maytag MAT12CSD Top-Load Coin Operated...
WHAT DO YOU HAVE TO DO TO FIX A FRUITMACHINE. WHEN YOU PUT IN MONEY IT JUST DROPS BACK OUT AGAIN
It's either 1 of 2 things. The coin mechanism or bill acceptor is malfunctioning, it will need to be repaired, if you can't see what's going on with it by looking. 2 - The machine itself has a problem, and is telling the coin mech/bill validator the machine is out of order, and not to accept money for this reason.
Mar 16, 2011 | Video Game Consoles & Games
We have a maytag dryer that is coin operated in our home. We want to shut the coin operated part off. how do we do that?
remove change acceptor usually 5/16 stud bolt in timer mechanism, theb remove change slot stops and reinstalll mechanism and bolt then just push in and pull out just like if you would of used change but dont need two
Jan 31, 2011 | Maytag Coin Operated Stacked...
Maytag commercial washing machines/dryers that use tokens. is it easy to convert these to accepting coins instead? how is this done?
push in slide coin acceptor,b48b65c.jpg requires different slide
multi coin single slot acceptor, ee120a2.jpgneeds new program
Oct 28, 2008 | Maytag Washing Machines
Standard Changer Equipment Standard MC520RL-DA Bill to Coin Changer Rear Load for Change or Toke Logo
70 people viewed this question
Top Standard Changer Equipment Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Standard Changer Equipment Retail Supply Expert? Answer questions, earn points and help others
