Question about Craftsman 26 Hp 54" Deck Yard Tractor
6" uncut strip of grass on 54" wide deck
54" deck, sharpened blades, leaves a 6" wide strip of uncut grass, dont understand how only 6" wide if blade is over 12" wide??
  • same463 May 11, 2010
    Is the strip of uncut grass in the center? Normally there is a strip left when the blades are worn down and don't cover the area under the deck as intended. Since your deck is 54 " wide your blades (I'm guessing there are three blades) should be a lot longer than twelve inches even if the deck is timed so the blades miss one another.
4 Suggested Answers
SOURCE: uncut strip in middle of 42 inch deck brand new
My first thought is that the blades are too short. If it cuts everywhere but in the middle, I'm wondering how it could be anything but that.
Charlie
Posted on Aug 14, 2009
bbreton
  • 437 Answers
SOURCE: I have a 19hp craftsman 42 deck. It has two
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Posted on Sep 26, 2009
  • 3911 Answers
SOURCE: I have 11 years old Murray (42 inch deck). After
On a two blade deck, such as yours, there is generally an overlap between the cutting coverage of the blades so that you do not leave a mohawk. This does not work well on turns however, and the sharper the turn, the more grass is left. Overcoming that issue brings you up to a 3 blade deck. If your mower is leaving a strip of uncut grass while cutting in a straight line, somehow you are running blades for a smaller deck, thus there is no overlap. The mandrels are offset, one slightly in front of the other so that the blades do not hit each other. I would measure under the deck and see how long a blade could be and still fit within the deck and not strike the other blade, then ask a parts store to sell you something longer than what you have now.
Posted on Oct 20, 2010
Cant get blades to full RPM replaced all idlers all belts greased spindles new elec. clutch new blades when cutting grass it leave rows of uncut grass
if the blades wont get up to speed or not cutting grass you have a belt that is slipping. could be the pulley is damaged or just a worn out belt. if it is leaving a strip of uncut grass you have a blade that is wore down on the ends not cutting the full path
Aug 05, 2017 | Garden
I have a Craftsman SL3500 42" riding lwan mower. the two blads make uneven paths ans the left blade makes a cut about 1/4" lower than the right blade. What do I do?
You should be using a up lift blade it will help by sucking up the grass to be cut. You should have an adjust on both sides of the blade deck . As for the strip check to see if you have a wheel behind the mower deck. If you do it might be the cause for mower leaving a strip uncut . Sears has been noted for putting wheels in the path of the blade area and smashing the grass down . That is also why I suggest to use an up draft blade it should **** the grass back up again so you can cut it.
Oct 07, 2013 | Craftsman Garden
Why is my husqvarna zero turn leaving a strip of uncut grass on the left side of the deck
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
Mar 24, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Uncut grass in center & higher grass cut on right.
Hi, this may sound obvious but make sure the new blade is the same type as the old one and make sure it is not fitted upside down. Spin the blades and make sure the tips are level with each other, this will tell you if the deck is straight where the blade spindles mount. Regards Phil.
Jun 24, 2012 | John Deere Garden
My 2 year old Husqvarna riding mower, with the welded steel deck, has the mulch kit installed ( I installed it). When cutting, the mower ususally leaves a thin line of uncut grass. More, when the grass...
I too have had that same problem. I found that "old" blades when repeatidly sharpened and worn will cause the same problem, also aftermarket blades instead of original manufactures recommended blades may not be dimensionally correct, too short. I have had to go back to using original blades to correct the problem.
This should work for you.
Good luck.
Sep 06, 2011 | Husqvarna Lawn Tractor  25 HP 54in Deck...
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
I have 11 years old Murray (42 inch deck). After deck adjustment still leaves uncut portion of the grass between blades. Should I exchange the blades (I have not done it for many years, but I sharpened...
Oct 20, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower leaves a uncut srip of grass through the center of the mow area!
The blades need inspected and sharpened,one could have a bent tip or just dull,if youve had someone else pull them off and reinsall them already check to make sure one of them isnt installed backwards,dont laugh,Ive seen it happen.
Aug 08, 2009 | Husqvarna 22 Hp 46" Deck Yard Tractor
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Craftsman 26 Hp 54" Deck Yard Tractor Logo
284 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
