Question about Danby DDR7009REE Dehumidifier
HOT AIR FROM DEHUMIDIFIER
ADEL70LR JUST BOUGHT WOKS HUMIDITY WENT DOWN BUT TEMPERTURE WENT UP IN THE ROOM
3 Suggested Answers
bobicehouse
  • 1524 Answers
SOURCE: the compressor of the dehumidifier does not work
Try a hard start kit for the compressor.
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: I bought a Dandby dehumidifier
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Posted on May 27, 2011
Plug it in turn it on and nothing in the bucket after several hours
Hi, Mindy! The following is an overall review of what causes the problem you listed.
If the room air is less than the set air, then there is no water in the bucket, because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water. In addition, if you set the humidity level you want to maintain higher the actual humidity level in the house or room, it won't pickup and collect any moisture. The fans on most of the dehumidifiers on the market today run almost constantly. They do this, so that the room air is always moving and if humidity is detected, it will extract it.
Hope this helps you understand how dehumidifiers function and what you can expect from them under given circumstances,. In fact, there may not be anything mechanically wrong with yours. But, to make sure, do what is suggested above to test the unit.
Apr 29, 2011 | Haier Dehumidifiers
Compressor sounds as if its on, the fan is on, but water is not extrated from the air
If the room air is less than the set air then there is no water in the bucket because there is almost no humidity in the air. If it is winter, there is likely not enough humidity in the air to have water collect in the bucket. A dehumidifier will only pick up humidity out of warm air. If you are running a dehumidifier in your basement in the winter, the room may be damp, but too cold for the dehumidifier to pull out the humidity. Try running the unit in the bathroom after having a hot shower without the bathroom fan on. If working correctly the unit should draw water.
In addition, check to see if the air filter is dirty and/or blocked. Also, the room temperature might be too low, (below 15.5 C/ 60F) and finally, check to make sure that there is no obstruction to the unit, that might be causing poor airflow circulation.
I hope this helps you to troubleshoot and solve the problem.
Apr 28, 2011 | DeLonghi DE500P Dehumidifier
My Goldstar dehumidifier model DH304 runs,but fails to pick up any water
Other things that can cause problems: 1.Check to see if the air filter is dirty and/or blocked. 2. The room temperature might be too low, (below 60 degrees Fahrenheit ) 3. Check to make sure that there is no obstruction to the unit that might be causing poor airflow circulation.
Hope this helps you to troubleshoot & solve the problem.
Apr 28, 2011 | Goldstar DH304 Dehumidifier
Freezing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground).
Turn the unit off until the room warms up.
Good luck
Aug 19, 2010 | Kenmore Dehumidifiers
Freesing up and bucket not filling
The coils you see on the back of your dehumidifier are the evaporator. When the unit runs, the coils get very cold. As the fan draws the room air over the coils, the humidity in the air condenses out of the air onto the cold coils. But, if the temperature of the air the fan draws over the coils is too cool, the humidity that condenses out of the air freezes on the coils. To remedy this problem, you can try any of these: Warm up the room the dehumidifier is in. Put the dehumidifier on a sturdy table (the room air is coolest near the ground). Turn the unit off until the room warms up.
Take care.
Aug 19, 2010 | Kenmore 5230 Dehumidifier
My dehumidifier ices up. It will not remove moisture when it ices up. What can I do and is it under warranty?
Take care.
Aug 10, 2010 | Fedders A7DH45B2A Dehumidifier
Dehumidifier making room very hot
Humidity, [Swetting] until the Room is totally dried out.Remember you are also drawing off infloor and underfloor dampness too.
Regards,DT
Aug 30, 2009 | Goldstar DH504EL Dehumidifier
My Danby DDR586R dehumidifier shouts hot air, it was shooting cool air before, what can the problem be?
Here is Danby's official response to a similar question on their FAQ page for Dehumidifiers:
https://www.danby.com/faqs.php?cat=12
Q) When the dehumidifier is operating, is it normal for the expelled air to be quite warm? We find that the dehumidifier is warming up the room noticeably (a finished basement).
A) The warm air that is being expelled from your dehumidifier is normal. When the unit is dehumidifying the compressor is working which causes the compressor to become quite hot. In order to avoid having the compressor overheat, air is drawn by the compressor at a rapid rate and the heat is then transferred to the air which must be expelled from the unit. The warm air will stop shortly after the unit has reached the desired humidity. This warm air should not change your room temperature by more than a degree or two.
May 07, 2009 | Dehumidifiers
Dehumidifier automatic on and off function not working
Unless you live in a dry environment or place the unit in a hermetically sealed room, it probably will not turn off. As the air dries within the room, more moisture comes in with the air. As long as the air outside of the room is more humid than the room this will be true.
Mar 10, 2017 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifier Present % indicates "Hi"
It is showing high because the present humidity is above 80%. Try turning the humidity setting down and let the dehumidifier run for a while. Once the dehumidifier lowers the humidity in the room this level will go lower. If this persists after running for a while you will need to contact LG for service. They back these models with a 5 year warranty. Here is the number to contact them at:
1 (800) 793-8896
Keep me posted. Thaks - Tech101
Jul 25, 2007 | LG LD65EL Dehumidifier
Danby DDR7009REE Dehumidifier Logo
54 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
