Question about Ovens
Sauter oven locked and will not come on
Oven is showing a lock on dial and i do not know how to unlock it
  • 236 Answers
SOURCE: Oven Door Locked
is it locked in the up or down position?
Posted on Jun 04, 2007
vest6
  • 196 Answers
SOURCE: oven locked and I don't know how to unlock
To unlock the oven. Switch the beaker off for 5 minutes. This will reset the integrated system. Turn the unit back on and if it doesn't unlock, set the unit for self clean and let it engage. Waite about one minute and cancel the self clean cycle. This should unlock the door(s).
Posted on Jan 26, 2008
SOURCE: oven door lock
Hold oven door light in while touching clean cycle enter up arrow or down arrow then hit cancel. door will unlock.
Posted on Nov 18, 2008
  • 29 Answers
SOURCE: My Kenmore Oven door won't unlock
Try throwing the electrical breaker off and then on to see if it will reset. If not you could put it through another cycle to see if its a jammed armature. However either the door lock motor armature is jammed or the motor is the problem or the solid state did not recognize the cycle was over. If you open the breakers and remove the covers to access the mounting screws you can work the unit out of the wall. Be sure to place some heavy towel or card board on the ground to keep from damaging the floor. Watch placement of your hands and depending on your fittness level you may need a hand pulling and replacing the unit. Test the electrical supply to ensure that its not energized. Then try disengaging the lock armature. IF YOU OPT TO REMOVE THE LOCK THEN THE UNIT SHOULD NOT BE USED IN THE CLEANING CYCLE, EVEN THOUGH THE UNIT SHOULD NOT FUNCTION WITH THE LOCK DISENGAGED, YOU NEVER KNOW ABOUT ELECTRONICS AND IF IT RAN IN THE CLEANING CYCLE SOMEOEN COULD OPEN IT AND GET BADLY BURNED. SO DONT DO IT. You should be able to order the parts needed on line at this website. http://www.searspartsdirect.com/partsdirect/index.action?intcmp=xsite_Sears Best o Luck :?) DRRXR
Posted on Feb 15, 2009
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
Posted on May 05, 2009
Sauter oven
Try pressing and holding the locked icon for a few seconds and it should go out
Apr 19, 2014 | Ovens
How can I unlock my oven
Set the oven to pyro clean, let run for 5 mins, switch selector dial to off, leave for approx 10 mins and the door lock should deactivate
May 17, 2013 | Gaggenau EB 270/271 Electric Single Oven
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    What does the sign "control lock" mean?
    Here is what the manual for your oven says about control lock.
    Let me know if you have questions.
    Control Lock
    The Control Lock shuts down the control panel pads to prevent
    unintended use of the oven(s). The Control Lock will remain set
    after a power failure, if set before the power failure. The only time
    it is not available is during the Sabbath Mode or Self-Clean cycle.
    When the control is locked, only the TIMER SET · START, TIMER
    CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
    CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
    function. On double oven models, CLOCK SET · START will also
    function.
    The Control Lock is preset unlocked, but can be locked.
    To Lock/Unlock Control: Press and hold CONTROL LOCK for
    about 3 seconds, until “CONTROL LOCK” and a picture of a lock
    appear on the display. Repeat to unlock and remove “CONTROL
    LOCK” from the display.
    May 13, 2010 | KitchenAid SGL OVEN T/C
    Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
    My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
    Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
    Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
    Kenmore oven locked
    Hello dktshopping,
    I know you probable don't want to hear this but in you circumstance, I think you would be better off to contact a repair professional. Those oven door locks are meant to keep the door from opening during the oven's self-cleaning cycle. They are both mechanically and temperature controlled so that the door can not be opened when the oven is 950 degrees. It sounds to me as though something is not releasing to allowing the locking mechanisim to disengage from the door even though the lever is in the unlock position. The unit will probably have to be taken apaprt to remedy the problem. Good luck.
    Nov 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
    Oven Door Locked
    the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
    Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidare Self Clean Oven
    I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING:
    1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING
    2. TURN THE "SELECTOR" AND/OR "OVEN" DIALS TO THE LOCK (OR CLEAN) POSITION
    3. PRESS THE "COOK TIME" BUTTON
    4. SET THE CLOCK TO 2 OR 3 HOURS (I.E., "2:00" OR "3:00"), DEPENDING ON HOW DIRTY THE OVEN IS
    5. PRESS "START" BUTTON
    6. YOU WILL HEAR THE MOTORIZED LOCK MOVE INTO PLACE; WAIT ABOUT 30 SECONDS, THE DOOR SHOULD BE LOCKED AND CLEANING WILL BEGIN.
    7. CLEANING WILL STOP AFTER THE TIME SELECTED (I.E., 2 / 3 HRS) AND THE DOOR SHOULD AUTOMATICALLY UNLOCK
    Sep 30, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    Top Ovens Experts
    Sal De
    Craig Butler
    Craig Butler
    Are you an Oven Expert? Answer questions, earn points and help others
