Question about Pioneer Televison & Video
Repair pioneer remote xxd3108 - Pioneer Televison & Video
Pioneer remote contyrol does't work with Pioneer 31FD blu ray
It will best to buy a remote control for TV, rather than try to repair this remote control. Sometimes, after repair, it won't work with Blu-ray; and it will be difficult to get a universal remote control for blue-ray. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Mar 02, 2014 | Pioneer Used Original VXX3351 Remote...
Pioneer VSX-D412 directv remote code
I also have the VSX D412 and DirectTV. My DirectTV remote controls the D412 fine, but I did have the same problem you're experiecing with a Sylvania flat screen that the remote wouldn't operate. I corrected my problem by turning the TV off, then back on using the TV's remote, then telling the DirectTV system that I didn't know the model number and let the system search for the code. Hope this helps.
Feb 17, 2012 | Pioneer VSX-D412 Receiver
Unlock code for pioneer bdp140
Switch on the player & Remove any disc
Close the tray
Press Home Menu on the Pioneer Remote
Select Initial Settings
"Press the hack button on the remote" <-- The IR signal hack that's for normal DVD players with Philips pronto etc
Select Options using the Pioneer Remote
Select Load Default
Once defaults are loaded complete the Settings Wizard
Switch Player Off then On again
Press Home Menu on the Pioneer remote
Type 8520 on the Pioneer remote
Region setting should now be 0
Dec 19, 2011 | Pioneer BDP-120 Blu-Ray Player
I need to know if the "pioneer audio multi-channel receiver SX-316" has a remote control.i just got it wondered if its possible to get a remote control for it.
Of course it does. No complex modern A/V electronics exists without a remote. They save money on front-panel indicators and controls my requiring a TV and a GUI to operate, too.
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A13102125354151&smodel=SX316&brand_pn=PIONEER_SX316
There's one on eBay, too.
http://cgi.ebay.com/PIONEER-XXD3108-AV-RECEIVER-REMOTE-CONTROL-/360376667427?pt=LH_DefaultDomain_0&hash=item53e81f8d23
Since you asked the question that means you don't have the manual either. You WILL need it.
You may have to register for free but it is here...
http://audio.manualsonline.com/manuals/mfg/pioneer/sx316s.html
http://dl.owneriq.net/e/e385684d-89d1-4c1d-bafc-0829f1879e06.pdf
Jul 09, 2011 | Audio Players & Recorders
Remote does not work
Check if the remote is emmitting a signal.
look at it with a digital camera. You should see a flashing light when using the remote (pointing it at the camera) and looking at it through the camera.
No flashing light. check the batteries and battery terminals. Most remotes can be opened. (Need to pry them a little) might need resoldering. Take it to Radio Shack $20 to repair. Or buy a new one. Web search Pioneer service.
Nov 19, 2009 | Pioneer VSX-D509S Receiver
I HAVE A PIONEER 50' TV AND THE TV REPAIR MAN WORKED ON THE COLOR CONVERGENCE AND NOW HE SAYS THAT I HAVE TO FINE TUNE IT? the main problem was the blue line.
YOU need to have the original Pioneer remote to do this--I do not understand if someone fixed and you had the remote why he did not adjust it?
With the Pioneer remote you go into the customer menu and adjust convergence--most also have a TECH menu for this but you still need the remote and a code to get into this--REMOTES FOR THESE SETS ARE HARD TO FIND AND EXPENSIVE.
Let me know if you have questions--I am here to help.
If this helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 12, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Non-functional pioneer remote
Hi
I did read through your comments, I am only going to offer advice to your original question. I have a great deal of experience in these matters and am confident you can repair the device, solving all your problems.
Your remote will most probably be repairable. There are only a couple of things that normally stop a remote from working. Most have been mentioned already across the various posts. To summarise then in order of probability:
  1. faulty batteries or battery connections.... Cleaning the terminals with an finger nail emery board,then a spray with contact lube spray such as CRC 2-26
  2. moisture or contaminants on the switch contact PCB(black carbon etchings) forcing more than one button to be "jammed on" See this TIP I have written. Also has details on how to get the remote apart.
  3. dry/cracked solder joints to the infra-red LED. Resolder the connections to the PCB.
  4. Faulty or dry jointed ceramic resonator 37e4657.jpgresolder first, they dry joint alot. If still no luck, replace the device with the exact same type. Contact me with the markings on it and I can provide you with information to source it.
  5. faulty IR LED.
  6. cracked PCB. Not repairable, you may be able to get a replacement PCB from Pioneer.
I have repaired hundreds of remotes over the years, and was a Key Service Agent for Pioneer for 12 years. If you are interested in repairing the remote, check out the TIP I wrote on how to get into the device, then go through the list above, then post back to me your findings. I am sure we can get to the bottom of it.
robotek
Aug 16, 2008 | Pioneer Audio Players & Recorders
Televison & Video Logo
47 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
