Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Dvd player stopped during play
Dvd v9800 will not load discs
SOURCE: Troubleshooting -- Displays H07 code
While stopped, press and hold REWIND and PAUSE on the unit and then also press and hold OPEN/CLOSE on the unit until Initialized appears from the display. Turn the unit off and on again. If it is still not working, Panasonic Consumer Support recommends having the product checked by an authorized Panasonic service center.
Posted on Dec 26, 2005
SOURCE: Plays CDs but not DVDs
Melisha, I had a similiar problem. Go into the onscreen menu with the remote using the "ACTION" button on the bottom left of the remote. Using the arrow keys in the center of the remote, move to the menu for the audio processing. It will have menu items for DTS, Dolby Digital etc. Change the menu parameters for the "Down conversion" to "yes", get out of the menu mode and see if your DVD works again. If not, make sure there is no DVD or CD in the player, and press the "open/close", "pause" and the double left pointing arrow buttons all at the same time for about 5 seconds until the display on the DVD player says "INITIALIZE". This resets your machine. I hope this helps you.
Posted on Mar 22, 2007
welcomejee
  • 10594 Answers
SOURCE: VHS to DVD-R dubbs fine: but won't play on SONY DVD player.
Please finalize burned DVD to play in another dvd player.
Posted on Apr 16, 2009
satavlad
  • 405 Answers
SOURCE: ERROR H02
Spindle motor in DVD mechanism require replacement, not practical to repair, just buy new one, upconverting DVD player would cost you less then repair of your old one.
Posted on Dec 01, 2009
supertech6
  • 513 Answers
SOURCE: dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
Posted on Apr 03, 2010
Samsung dvd v9800 only plays in black and white. Can this be easily and inexpensively fixed?
some of these will do this if one of the many settings is wrong, failing that not worth repair cost wise.
Oct 16, 2012 | Samsung DVD-V9800 DVD Player/VCR
Cassette is stuck. Cannot eject
Sounds like the tape is dragging and the spindle wont release it because of the torque on it. Can you rewind or fast forward to see if it releases?
Sep 09, 2012 | Samsung DVD-V4600 DVD Player/VCR
Wont play a dvd ntsc when computer will
is the dvd for your region? you cant play out of region discs. I.E. you cant play amercan dvd films on a uk dvd player and visa versa
Apr 07, 2011 | Samsung DVD-V9800 DVD Player/VCR
I have my Samsung model dvd V9800 hooked up to my RCA RT2906. The dvd side is showing a picture but the video side is not. The RCA RT2906 has have a hook up for a vcr player by it's self but I do not think...
VCR video signal wont come out from Component Video Out of combo unit, it is low resolution signal so you need to hook yellow-red-white video cable in tv for VCR output.
Make sure to select VCR as source in combo while playback of VHS tape and select DVD as source when playing dvd disc in combo.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Dec 04, 2010 | Samsung DVD-V9800 DVD Player/VCR
My dvd player reads no disc but i have put the disc in and it will not play
in that case the lens of your cd is bad try to clean it and if same occurs then you will have to change the lens thnks .
Jul 10, 2010 | Samsung DVD-V9800 DVD Player/VCR
Stopped during play, made cherpping sound, cannot remove dvd
try to replace the motor 5volts,co'z its weak to read the disc.then try to change the rubber of your disc loading tray.for a normal open close tray.(kira_ryuk99@yahoo.com) ronxin
Mar 11, 2010 | Philips DVP642 DVD Player
DVD Player stops reading disc Error message :
usually this happens when lens cannot read the the disc. Due to few reason 1 Your disk is scratched 2 Your DVD lens is covered with dust 3 You need to replace DVD lens
Try another few CD/DVD to rectify whether there is any problem with dvd you are trying to play
if this error occurs on all the dvd you played then the most likely proble is with your DVD lens either its coverd with dust use Disk cleaner if not you got to replace a new DVD lense as per model
Feb 18, 2010 | Samsung DVD-V9800 DVD Player/VCR
The VHS tapes will not playback on the Samsung TV (flat screen)..the Samsung TV is a Syncmaster 2333 HD...the Samsung dvd/vhs unit is a DVD-V9800 The DVD discs will play just fine. How should I be...
On these combo units, the VCR will not play using component cables but the dvd's will play just fine.
What you need to do is run a pair of composite (Yellow, red and white) cables and use that for VCR and component (Green, blue, red, white and red) for the dvd player.
Make sure you switch the tv to the corresponding input.
Dec 30, 2009 | Samsung DVD-V9800 DVD Player/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
11 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
