Question about Electronic Arts Shockwave Assault
Shockwave assault on windows xp - Electronic Arts Shockwave Assault
Con windows10 non ho installato il file shockwave
Hello
Depending the version of windows 10...
but it is suppose to install it, or do a windows update perhaps need to be update it.
Carl
Mar 03, 2016 | ValuSoft Men of War: Assault Squad
Swarm Assault's color scheme is corrupt on Windows 7.
I have the game too, played it on Win 95/98. You can do those for compatibility mode, or XP SP2/3.
Under that is the Settings. You can check all those options there (that's how I did it) and just run it with administrator mode.
There you have it, it's fixed, only problem I'm facing now is the blinking "windows circle" from the start bar. That is all.
Mar 06, 2012 | Gate 5 Creations Swarm Assault
Why does my flash shockwave keep crashing every 19
Its Not a Flash shockwave issue, your internet bandwidth is lo that’s wise this types of issue is coming on your system
Nov 16, 2009 | Microsoft Windows XP Home Edition
Upon rebooting the computer of our gateway, windows 98 xp media will not load,,, we receive a black screen that describes: We apologize for the inconvenience, but windows did not start successfully. A...
hello there
here are a few links that just might be able to help you out ok
best regards michael
  1. Annoyances.org - cdrom media, does not identify (Windows XP Discussion ... ... tips, fixes, workarounds, and answers for Microsoft Windows XP, 2000, Me, 98, NT, and 95 ... on "my computer" and will not load into any audio program. ...www.annoyances.org/exec/forum/winxp/1073187041 - Cached
  2. Adobe - Web Players Broadcast and media. Education. Financial services ... (1) Not officially supported by Adobe. Shockwave Player (System Requirements) Windows 98/2000/XP ...www.adobe.com/shockwave/download/alternates - Cached
  3. windows xp will not load windows xp will not load : Archived from groups: microsoft.public.windowsxp. ... Tom's Hardware: Topic windows xp will not load ... Windows Media DRM cracked ...www.tomshardware.com/forum/59109-45-windows-load - 62k - Cached
Sep 14, 2009 | Office Equipment & Supplies
Hello Have just bought Medal of Honor Allied Assault Deluxe Edition - installed it, but when I want to play it crashes to desktop. Any ideas? Simon
Vista - try to run as administrator
XP - try uninstall it, reboot and press F9, go safemode, install it in safe mode. if nothing happens reboot again and login to your normal user and install the game. now it should work fine =)
Dec 31, 2008 | Electronic Arts Medal of Honor Allied...
Shockwave player
Try to download shockwave from this website. http://get.adobe.com/shockwave/ and then save it first to your computer then run it. This is its requirement for PC windows:
  • Intel Pentium IV 600MHz or higher
  • Microsoft® Windows® XP Service Pack 2 or later
  • Microsoft Windows Vista
  • Microsoft Internet Explorer 6.0 or later
  • Firefox 2.0
Also, I believe shockwave requires some flash updates on your computer and java update. Did you run updates on java and shockwave? Plus make sure that when you are installing shockwave you have admin rights and you anti-virus is not seeing it as a virus.
Dec 09, 2008 | Computers & Internet
Adobeshockwaveplayer
To download and install Adobe Shockwave, go to the website listed below and follow the instructions on the page.
http://www.adobe.com/shockwave/download/
I hope this has helped to solve your problem, good luck!
May 15, 2008 | Microsoft Windows XP Professional With...
Flash 9 freezes after 1st. video plays on The Fan.
Lets Start from here:
Before you install Shockwave Player for any Windows browser, uninstall all previous versions.
In order to remove the Shockwave player, simply use the file UNWISE.EXE located in C:\WINDOWS\system32\Adobe\Shockwave 11. Windows users can also use the Add/Remove programs located in the Windows control panel. This will remove the Shockwave 10 player
For the Shockwave 8 and 8.5 there is an uninstaller available from the Web Players page.
Note: All applications must be closed before you run the Shockwave Player uninstaller. Quit all running applications, including all Internet Explorer or other browser windows, and all Instant Messenger clients. Check the Windows system tray carefully to make certain no applications which might possibly use Shockwave Player are still in memory.
After you have removed previous versions, you are ready to download and/or install Shockwave Player.
Before installing Shockwave Player, please check the following browser settings:
Internet Explorer ActiveX settings
Browser security settings should be chosen by you or by your system administrator. For single users who do not have an administrator, the Medium: Default Level allows you to view Shockwave content. For any Custom Level, ensure that both the "Download Signed ActiveX controls" and "Run ActiveX controls and plug-ins" options are set to "Prompt".
To change security level in Internet Explorer:
1. Open Internet Explorer.
2. Choose Tools > Internet Options.
3. Select the Security tab.
4. Select Custom Level.
5. Find the section "ActiveX controls and plug-ins".
6. Set ' Download Signed ActiveX Controls' to Prompt.
7. Set 'Run ActiveX Controls And Plug-ins' to Prompt.
If you are having trouble installing, make sure that your Internet Explorer security level is not set to High or to a custom level that does not allow viewing of ActiveX controls.
Computer user permissions
User permissions determine whether or not you are allowed to install ActiveX controls or plug-ins. If you don't have Administrator access to Windows XP SP2, or Vista you may not be able to install Shockwave Player successfully. Administrative privileges are required for the Windows system registry and for the C:\WINDOWS\system32\Adobe\Shockwave folder.
If the ActiveX Control for Shockwave Player fails to install, download the executable installer.
If the information above has not resolved the issue, download the executable Shockwave Player installer here:
* Download and latest Shockwave Player Installer.
Save this installer to your desktop, close out all applications, and run the installer. This may help if you are having trouble with the ActiveX installation from Adobe.com. To confirm that Shockwave Player has installed successfully, please click here. The two movies will show if you have Flash and Shockwave Players installed. The version numbers of the both Players will be displayed in the test movie.
Apr 16, 2008 | Computers & Internet
Electronic Arts Shockwave Assault Logo
15 people viewed this question
Top Electronic Arts Computers & Internet Experts
Tom Chichester
Tony
Martin Murray
Are you an Electronic Arts Computer and Internet Expert? Answer questions, earn points and help others
