Question about Stanley 1800 PSI 1.4 GPM Electric Pressure Washer P1800S
Water leaks from inside the power washer - Stanley 1800 PSI 1.4 GPM Electric Pressure Washer P1800S
Washer is leaking
sounds like you have a hose problem. are the hot and cold water hose connections tight? they may need new washers. if that is the problem turn off water valves,disconnect hoses and replace them with garden hose washers from any hardware store. re-tighten them snugly. just tight enough so they don't leak. if it only leaks while draining, replace the short hoses connected to the pump,located inside bottom of inside of washer.
Sep 16, 2010 | Kenmore 9781 Electric Laundry Center with...
Whirpool Ultimate Care II washer - drips
Your water inlet valve is leaking through. Turn off the water. Remove the hoses from the washer. Clean the sediment screens in the water valve and replace the hose.
If that does not solve the leak through problem,the water inlet valve will have to be replaced.
Use the attached video to show how to access the inside of the washer in the event the water valve needs replacing.
http://appliancejunk.com/forums/index.php?topic=5191.0
Nov 08, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Leaks water inside washer overnight
Could be water fill valves ,,try turning them off for a few nights if this workds ..hey presto..if not could be drain too low,, water entering via sink outlet /drain....in this case raise hose..hope this helps you can let me know.....
Sep 29, 2009 | Washing Machines
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Were water inlet hose connects to housing on washers left side, water is leaking seems to be a washer or valve that mounts on the inside of washer might be missing but have not found any such object inside...
Hi, There is some lime build up inside the inlet. Remove the hose and push a wire or a small screw driver into the hole and reem it out. That should yake care of the water leaking.
Please let me know if this helps you.
Vic
Jul 03, 2009 | Dishwashers
RUBBER RING INSIDE THE WASHER
if the washer is still leaking, take the outlet pipe and place it in a dish on the floor , the water is greater and should come out of the pipe, keep watching until empty . remember there can be a lot of water in a washing machine
May 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer is leaking while it is just setting still.
The first thing that I would check, is the hot & cold water hoses, that connect in the back of the washer, to see if they are tight. If they are tight and still leaking from there, then the rubber washer, inside the brass fitting part needs replaced. If that doesn't help, then disconnect the power, and water hoses, then turn the washer over and check the water hose underneath, to see if its leaking. One of these hoses has to be the problem.
Jan 23, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer continues to leak fresh water into washer tub
This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stanley 1800 PSI 1.4 GPM Electric Pressure Washer P1800S Logo
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
J.D. Browning
J.D. Browning
Are you a Stanley Garden Expert? Answer questions, earn points and help others
