Question about Stihl Ts400 Cut Off Saw Piston Cylinder Rebuild Kit
Which way does the arrow point on a stihl piston ts400
    Problem Solver:
  • 12 Answers
The arrows on all pistons face to the front of the engine
Posted on Jan 26, 2015
Original parts diagram for stihl ts400
I found a parts diagram for a Stihl TS400 CutQuick concrete saw here: http://www.sawagain.com/stihl-concrete-saws-1/ . The direct link to the parts diagram is http://www.hellumdiamant.com/filarkiv/File/Sthil/ts400.pdf . I found some of the parts shown in the user manual as well. The manual is available here: https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/TS400_Manual.pdf . See page 44 for that parts diagram.
I hope this helps.
Jul 18, 2017 | Stihl Saws
Stihl TS400 stone cutter not working (no compression) so replaced piston rings, new gasket kit and clean for carb new spark plug (good spark when engin turned over) cleaned all air filters, replaced all...
You did not indicate whether or not you have compression now that you have changed out the gaskets and piston rings. If not, it seems to me that the problem could be a) cracked head or block, b) bad valve(s) or even c) a warped head.
Sorry for the bad news (if I am right).
Apr 23, 2014 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl ts400 quick cut won't draw fuel. New carb installed same problem exists. I am now getting beyond frustrated. It will start and run for a moment on carb cleaner but when its out of carb cleaner i
Check the boot between the carb and the cylinder, it could be an air leak. also check the compression. If the piston rings are damaged then it wont have the compression to pull the fuel through. Could also be a damaged fuel line, or plugged filter.
Dec 10, 2013 | Stihl Ts400 Cut Off Saw Carb Carburetor...
Stihl Repair Manual
arrow points towards exhaust, direction of gasses http://www.mediafire.com/download/56zr9s967sf9a98
Oct 22, 2013 | Stihl Garden
What why dose arrow on piton go on a ms 170 to front or rear
The 'Arrow' on the piston always points in the direction of air flow through the cylinder. So it should be pointing towards the exhaust port. :)
Mar 08, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Hi, My Stihl TS400 with 14"
Racing on a 2 cycle engine is usually a sign of a lean condition. It could be caused by a few different things including a bad crank seal or a torn intake manifold as some are made out of rubber. I would remove the cutter arm then pull the muffler to inspect the cylinder and piston. If they are scored it will be a costly repair.
Jul 14, 2011 | Stihl Concrete Cutoff Chop Saw Clutch...
Stihl ts400 will not stop, it carries on running. Where can I get hold of a service/repair manual
Stihl guards their service manuals making them only available to dealers who service Stihl.the kill switch is not making contact. a t25 torx should get you to the point where you can determine if my theory is correct.
Feb 26, 2010 | Saws
Piston of a ts400 cutquik saw is seized in the housing
What did you expect? Find a engine rebuilder and get ready to spend about 75% of a new replacement.
Jul 16, 2009 | Hand Tools
Stihl Ts400 Cut Off Saw Piston Cylinder Rebuild Kit Logo
475 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
