Question about Miele Novotronic Premier 500 Front Load Washer
Water intake miele w918 - Miele Novotronic Premier 500 Front Load Washer
2 Suggested Answers
mastertec14797
  • 318 Answers
SOURCE: Miele novotronic w918 keeps filling with water, whether turned on or off! Help!
Hello. Based on your symptom, I strongly suspect a defective inlet water valve if the power is removed and the unit keeps filling--that's your clue. Trash like sand or sediment might have somehow gotten past the fine water screens at the hot/cold hose connections and jammed the valve. Or, the valve(whichever one is allowing water in) could simply be defective. Now, if power is removed and the unit stops filling, I would be looking at the main control board as the likely culprit--probably a stuck relay on the board causing the issue. I hope this helps you.
Posted on Nov 07, 2015
Nov 07, 2015 | Miele Washing Machines
Miele w918 washes much longer now than before. About an hour longer, even with shortened program. Any ideas?
Maybe the water is not getting into the machine as quickly as it used to. You may have a filter on the hose connection. Does the water appear to be filling as fast as it did before?
May 19, 2015 | Miele Washing Machines
How do I fix a Miele G2470 SCVi with an intake/drain fault
Look for item(s) blocking the drain, inside bottom, and remove them.
May 24, 2014 | Miele Dishwashers
Red intake light comes on and dishwasher will not drain, model g 843 scvi
The manual is available here: http://www.miele.ca/miele/canada/OperatingInstructions/manuals.asp?ParFolder=Dishwashers&SubFolder=Previous%20models . Scroll down through the list to the G643 G843 Incognito. The maintenance items listed below are detailed on page 44 and beyond of the manual.
The Intake light is also the Drain error light. If the light is flashing, then turn off the dishwasher and clean the triple filter, the drain pump and the non return valve and make sure that there are no kinks in the drain hose.
Make sure the water is ccoming in at a pressure above 4.5 psi. Also make sure that the water valve is open and clean the water intake filter.
The final possibility is that the Waterproof system has tripped and you need a Miele technician to service the unit.
I hope this helps.
Feb 19, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
Water intake alert coming on however the water is turned on. No water seems to be entering the dishwasher.
No water intake, may be a defective intake hose valve. Miele calls it, the Waterproof System hose (WPS). However, first shut off your water valve to the dishwasher; disconnect the WPS; and inspect and clean the plastic filter. If the problem persists, then replace the WPS (~$170).
Oct 17, 2010 | Miele Premier-Plus Built-in Dishwasher
F 13 problem indicated on miele g2420 optima dishwasher
Its on the end of the water intake line - ussually under the sink - connected to the hot water line.
Dec 06, 2008 | Miele 24 in. Incognito G843SCVi Built-In...
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele intake/drain flashes, no drain
this can happen after inactivity. the circulation pump seal sticks and wont turn . when the dishwasher starts to fill the circulation pump is pulsed on to see if the preasure switch switches over (to see if water is getting into the dishwasher) if the pump does not turn there is no preasure and the machine stops thinking no water has entered. turn pump by hand to cure.
Jul 18, 2008 | Miele 24 in. Touchtronic Platinum Built-in...
Miele Novotronic Premier 500 Front Load Washer Logo
26 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
