Question about SALTON INC Cooks Essentials CEPC600S 6 QT. Pressure Cooker
Need p/n21777 need to replace peeling inside
Inside of microwave top peeling and blistering
If it's paint peeling, then once that paint is gone, rust will set in, which can cause arcing and disintegration of the chassis, when ruins the oven.
This peeling is usually the result of excess moisture accumulating in the oven due to blocked air vents or poor fan circulation.
Once those two issues have been ruled out or dealt with, then always be sure to dry out or leave the microwave open after use.
The peeling paint will need to be removed, then the area should be sanded.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 28, 2011 | Morphy Richards AM925EF Microwave Oven
The water line in my Kenmore side by side fridge broke in the door how do i remove the inside panel to replace the line??
It's a shot...but if I recall correctly the rubber seal thats between the door and the fridge can be peeled back or removed, and underneath are the screws that hold the inside panels on...
I would peel the seal back a little at a time until I actually locate a screw...then once located... I would feel more confident about the removal of the entire seal. Keep in mind the seal is much easier to remove than to replace...I used baby oil in some place to replace the seal...Good Luck!
Dec 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Plastic over the outer edge of jog wheel on cdj800 is peeling
The jog wheel assy' is in several parts. email me a picture and I'll get you a price for the part you need.
mail@technicsdjuk.com
http://stores.ebay.co.uk/methleykev
Jun 27, 2009 | Pioneer CDJ-800MK2 Turntable
Paint inside lid peeling off when I cook
From Weber.com Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Apr 25, 2009 | Weber Genesis Silver C Grill
The finish on the inside of dryer drum is peeling
Probably due to the age of the dryer, and continous use, especially if it has been used on high heat settings, also the continuous action of clothes turning and thigs like zips and buttons will contribute to wearing away the enamel.
Dec 11, 2008 | Hotpoint Dryers
Inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
Nov 21, 2008 | Microwave Ovens
Peeling paint
Here is a link to buy the paint.
If the microwave is not creating a spark inside when in use, It's OK to use.
Mar 09, 2008 | Rival MT660 Microwave Oven
Peeling interior
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
You can sand the peeled area, even the rusted area in most cases, clean them squeaky dry, and repaint with high-temperature appliance paint available from places liek Wal-Mart, home improvement centers, and appliance parts stores.
No need to replace the microwave if you can clean and paint it properly.
Oct 16, 2007 | Goldstar MA-1011 Microwave Oven
SALTON INC Cooks Essentials CEPC600S 6 QT. Pressure Cooker Logo
Top SALTON INC Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a SALTON INC Kitchen Appliances - Other Expert? Answer questions, earn points and help others
