Question about TC Electronic M350 Dual Engine Reverb and Multi Effect Processor
Blown fuse m350
Blown fuse
Spb karaoke machine blown fuse 250volt 2amp changed it checked plug in wall still no power what could it be pls
You may have blown a component of the power supply, which is what took out the fuse in the first place. Probably will need a trip to the repair shop.
Aug 19, 2016 | Music
BEHRINGER K3000FX will not power on
It may be likely that you've blown a fuse. This will require removal of the amplifier unit from the housing. The fuse is a 100-120 V~: 6.3 A H 250 V. You should be able to find this in most places. If the fuse is not blown, then the unit must be sent in for servicing.
Feb 18, 2015 | Behringer Music
B115D
Hi, your amp has a short if the fuse is blown - it needs to be repaired - we can fix it - look on ebay. Thanks.
Mar 12, 2014 | Behringer Eurolive B115D Powered PA...
Sp4 blown fuse
It's not a fuse, it is a lamp and I suggest ordering replacements directly from Peavey.
Dec 10, 2013 | Peavey SP4 2-Way PA Cabinet (2000 Watts,...
Roland ac 60 sudden loss of power. Is it the fuse?
If you mean it's completely dead, no lights or anything, then probably the fuse is blown. The question then becomes"what caused the fuse tio blow?".
If however, by loss of power you mean it's quiter but still producing sound, then the fuse is not blown.
Sep 08, 2013 | Roland Ac60 Acoustic Chorus Guitar...
Peavey cs1000x amp fuse blown
Power amp transistors failure.
Jan 18, 2012 | Peavey Music
I accidentally changed Dip switches and light has power but no fan and no light ..have I blown a fuse ..thanks
Not likely blown fuse. Verify the correct dip switch settings... SOMETIMES the switches don't quite move completely so make sure they are completely one way or the other.
Jun 17, 2011 | Chauvet Kinta 311X DMX DJ Color Lighting...
Please help. Cannot turn the soundcraft gigrac 600 on.
Check the fuse. If it has blown, do NOT replace it without taking for service first. Additional damage often occurs when users replace fuses that have blown due to internal failures in equipment.
Also check that the power cord is fully seated... sometimes they don't quite make it...
Feb 04, 2011 | Soundcraft Gigrac 600 Powered Mixer
The light is not working and the bulb is not blown.
These systems have many interlocks for safety. All doors must be closed completely. Also, there is usually a thermal fuse inside that may be blown. Did this stop during use or was it shutdown and now won't start again? If it was shutdown, perhaps it was unplugged before the fan stopped. If that is the case, the thermal fuse is likely to have been blown and will need to be replaced.
Let us know what you find.
Dan
May 13, 2010 | Chauvet Followspot 400g with Stand
I have a Lowery Genie 44, with a blown fuse
Do not change the fuse without finding out why it is blowen. If the glass is black DO NOT even think of changing it or you will cause more damage.
I think if you take out the fuse you will find the raring under the end caps of the fuse.
Nov 02, 2009 | Music
TC Electronic M350 Dual Engine Reverb and Multi Effect Processor Logo
29 people viewed this question
Top TC Electronic Music Experts
Michial Gueffroy
bigdawg7299
Tom Chichester
Are you a TC Electronic Music Expert? Answer questions, earn points and help others
