Question about Creda Washing Machines
I have a creda 950DL shower that is no longer providing hot water. It runs cold
    Genius:
  • Creda Master
  • 1,585 Answers
Heater seames gone
Posted on Feb 23, 2015
  • 1294 Answers
SOURCE: i have a creda simplicity 1000 front loader washer.
Maybe the pipes are not connected to the heater on the wall. You could heat your water in the machine, if there is a provision; most machines have it.
Posted on Dec 02, 2007
SOURCE: cold water trickle hot water runs good
turn off water valves at wall, disconnect the supply hoses from the washer. where the hoses connect to the washer, there is usually a stainless steel screen/strainer inline on both the hot and cold inlet. corrosion on the cold side is pretty common. Menards, Lowes Home Depot stores sell the replacment screeens.
Posted on Jan 25, 2009
  • 1244 Answers
SOURCE: We have a second hand Creda Simplicity W100
yes you can just connect the cold water side however you will need to cap off! the hotwater side due to a reverse flow issue when the tub is filling
Posted on Jan 17, 2010
Testimonial: "Thank you! Very quick advice!"
SOURCE: creda aqua wave 9.5kw electric shower, no hot
my Creda Aqua 9.5 shower loses water temp when water pressure is increased. i have a very low pressure at the moment.why?
Posted on Apr 30, 2010
  • 713 Answers
SOURCE: cold water runs hot even when hot water valve is t...
check to see if the cold tap is connected to the cold valve on the machine and the hot tap to the hot valve. on the machine it will have cold or c for the cold valve and hot or h for the hot valve. please reply if you need further help.
Posted on May 22, 2010
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
My Bristan Meridian Show start ok with hot water then after a few minutes the water runs cold. Even if you try and increase the temp it still remains cold. You can switch of the shower and start again...
It sounds like 1 of 2 things to me. I will start wit hot water heater. The first test for the water heater is to have someone run the hot water while you hold the hot and cold pipes and see if the water is coming out of the water heater cold when the shower goes cold. Of the water heater is cold coming out then the problem is in the heater. ether a lower element is bad or the dip tube is broken at the top of the tank. if the hot water heater continues to put out hot water when the shower goes cold then it has to be the mixing valve for the hot and cold mix at the shower and that valve will have to be repaired or replaced. hope this gives you a good start. let me know if I can help further.
Dec 24, 2010 | Home
My creda 950 t shower is pissing water out of it
If this is for a hot and cold water shower, you have to
replace the mixing valve to get the right result. However,
if you can get a repair kit for your hot and cold mixing
valve, you may repair it. And get it done.
Nov 24, 2009 | Plumbing
Tankless on demand water heater.
Tankless water heaters normally take a little longer than a regular heater to provide hot water because they have to start and get warmed up. I'm guessing the heater uses a pilot light and that the short amount of hot water when you turn on the tap is hot because when the water is sitting still in the heater the heat from the pilot light is enough to get it hot. The tub faucet will get hot a lot faster than the shower because it lets a lot more water through and empties out the pipes faster than the shower. You could probably speed things up by letting the tub faucet run on completely hot for like 10-15 seconds and then turning on the shower.
Oct 24, 2009 | RTO Takagi Jr. TK-JR-N Tankless Water...
Cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Oct 05, 2008 | Home
Washing Machines Logo
104 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
paul
paul
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
