Question about Sony RDR-HX725 DVD Recorder/HDD Recorder
Replace faulty HDD of Sony RDR-HX725(HDD ERROR).
My Sony RDR-HX725 has a faulty HDD (HDD ERROR) which I try to replace. Whenever I try the solutions provided on this site, my remote control does not work. Any suggestions?
So I can enter the support/service menu, but cannot select option 9 to write the ID.
Thanks in advance
Replacing the s-ata cable solved the hdd-error for me. (i use a logitech universal remote, so no sollution for your remote-problem, sorry)
Posted on Oct 17, 2011
I have the same problem, but no solution for me. Have you fix the problem? Could you use the remote successfully?
Thx
Posted on Jun 21, 2009
How to replace hdd on Sony RDR-HXD860 DVD Recorder/HDD Recorder?
The HDD must order from Sony It can not replace with the computer HDD.
May 04, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Dvd recorder keeps turning off
Power supply regulator board will ahve the fault. It is best to replace it as card basis.
May 02, 2012 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Sony RDR-HDC100 DVD HDD Recorder One channel (channel ten) stops recording after 9 - 12 minutes for a one hour show, when pre-set was done through the guide page. It works if preset is done through...
hi, i have the same device, with the same problem, i was told by sony service centre managment that this is a known error that is being researched to find a permanent resolution. They have no fix for it yet and said they will contact me when a solution is available, the only solution at the moment is to manually set timers for programs airing on channel ten, eleven and ONE.
Mar 03, 2011 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
C13:00 error code on rdr HX-725 when i put in a cd. DVD's are playing ok, so is the HDD.
Try to turn off the machine (deplug it) for at least some minutes - and turn it on again. That worked for me! ;-)
Dec 21, 2010 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Sony recorder rdr-hx750 How to reset to analog.no picture but there is sound on av
my problem is last time i did some thing on dvd but i 4get wat i did and now even the remot dosnt work i have frind he said to me i have to restart but i dont now how i do it pleas help me to find the problem ??thx
Oct 07, 2010 | Sony RDR-HX725 DVD Recorder/HDD Recorder
When I switch on my RDR-HX725 IT COMES UP WITH hdd error. What can I do to clear this concern ? I have a lot of stored data that I would prefer not to loose.
Sounds like you are going have to reset your device. When you do some you will loose all the data on your HD. You could always pay to have it taken off before you do this but the cost would be high. For info on these companies or people that perform this service just send me a comment and I can give you a few links to them.
Mar 18, 2010 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Sony dvd recorder as hdd error
try replacing the red sata cable which runs from the HDD under the DVD drive to the main board on the right-hand side. these are a common problem on these models, there cheap and unreliable. you can purchase a better quality cable from a computer store for little money. HDD ERROR is'nt necessery an HDD fault as i found out with my rdr-hx525. if however the HDD is faulty and you buy a replacement, once installed you will need to pair the new HDD with the unit by entering the service mode by unplugging the AC then while holding down open/close and play together then re-insert the AC lead while still holding open/close and play and wait until you see an "S" in the display then let go and the service mode will appear on the tv screen. go to no.9 HDD mode, press enter then go to no.3 Write ID then it will say "execute write ID?" yes and press enter and then it will say "writing HDD serial ID.... OK" once this is done, exit the service mode by keeping your finger on the power button for approx 10secs. your DVD recorder should now recognise the new HDD. if you don't follow this process, you will still have an HDD error message as your DVD recorder will have your old HDD installed and won't recognise your new one. given the amount of time since you posted this fault, you may still have the unit in question in which case i hope this solution is helpful, or for anyone else with the same problem.
Nov 11, 2008 | Sony Televison & Video
Recording from VCR to HDD
The VCR tape contains a copy inhibitor along it's length, so cannot be copied. the only way to make a copy is to use a truly analog route, without any copyright checking getting in the way. I think this is mentioned in the manual.
Feb 21, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Sony RDR -HX725 dvd recorder
I had the same problem, which, curiously, is slightly described in the instructions manual (towards the end) as an electrostatic problem. They tell you to unplug the DVD for 24 hours : it works but does not prevent it for doing the same thing later and, in my experience, in shorter and shorter times.
I decided recently to mount a ground with an electric thread from one screw behind the DVD to the corresponding plug : to day, I still hadn't any problem for seven weeks (compared with one month regularly and eleven days the last time.
Aha ! excuse me, I'm french and perhaps not perfectly bilingual...
Jan 19, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Hdd error
Jan 08, 2008 | Sony RDR-HX725 DVD Recorder/HDD Recorder
Sony RDR-HX725 DVD Recorder/HDD Recorder Logo
2,042 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
