Question about Boating
Suzuki dt 55 clutch linkage won't shift - Boating
4 Suggested Answers
  • 2920 Answers
SOURCE: after clutch replacement in 97 200sx, shifter linkage not alignin
have the linkage reset. its not very hard to do.
Posted on Jan 17, 2009
  • 52 Answers
SOURCE: 300 FOURTRAX CLUTCH
not the clutch. problem should be in the trans or the ratchet mechanism on the shift drum
Posted on Jun 12, 2009
  • 876 Answers
SOURCE: Clutch adjustment on a 1996 4700 International DT 466 Truck
You would usually find it at the flywheel area - on the clutch slave cylinder
Posted on Feb 07, 2015
1986 Suzuki Intruder 700 won't go into neutral
Hi, Lauren and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return springs weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Bike won go into NEUTRAL when idiling
http://www.fireblades.org/forums/honda-cruisers/90393-85-shadow-transmission-problems.html
Suzuki VS700 1985 Service Repair Manual
OEM parts for Suzuki
Suzuki VL800 Owner Manual
Feb 10, 2017 | Suzuki Motorcycles
Replaced clutch and now won't shift into 1st, 3rd, or 5th gear
if it worked before why a new clutch,,,(context wins, here/??????)
ok, so you the clutch is failing,
you never posted the symtoms, not really
does car start in gear with clutch depresses, or start to move
does car take off in 1st ?
or is it just moving fast issues>????
cant up shift, cant down shift
hard to shift. (blocks)
grinds.
my wild guess, based on no input is the clutch linkage,
was never adjustED
the side kicks (not sport 1.8L) all have
cable clutches, and the 1 inch rule stated here.
i bet you didnt adjust it or the linkage splines are damaged.
or the pedal is cracked , caused by bad cable.
always replace the cable first. is it breaks other things if not.
http://www.fixkick.com/tranny/clutch/clutch-on-kick.html
tell the full story and get ,very accurate tests to do,
and inspections.
Sep 02, 2014 | 1995 Suzuki Sidekick
My 06 suzuki boulevard C50 will not take any gears they all seem to be neutral,anyone know what it could possibly be?
Possibly your clutch is worn beyond any usefullness, or is out of adjustment.
Could also be a broken shift linkage.
Sep 05, 2013 | 2006 Suzuki Boulevard C50
Frontier shift
this is covered under your vehicle warranty if not its time to replace clutch already and check linkage cables for inproper adjustment as its riding the clutch or your foot is
May 23, 2013 | Cars & Trucks
5-Speed transmission;Won't shift into gear.
If you can shift it with car off, but not with engine running, it is a clutch poroblem. Check the fluid level in the clutch master cylinder on the firewall next to the brake master cylinder. If it won't shift with engine off, either the shift linkage is binding, or there is an internal problem in the transmission.
Jan 15, 2013 | 1992 Daihatsu Rocky
Suzuki won"t shift into gear unless I turn the car off and put it into first
make your adjustment to clutch, see how that works, but start saving up for a new clutch, or just have your inspection mechanic, take a look @ it for you, make the adjustment, and he can remove a cover and inspect the condition of your clutch with his own eyes. its a lot easyier for him than you. then, you'll know for sure. good luck
Jan 13, 2013 | 2001 Suzuki Grand Vitara
2000 mazda 626 5 speed manual transmission is stuck in a gear and won't shift out
A clutch problem will not interfere with gear selection when the engine is off and the car stationary.
It does seem like you have a gearbox or gear linkage trouble.
Sep 16, 2017 | 2000 Mazda 626
Kawasaki vulcan won't shift into upper gears above neutral.
Broken selector claw spring
Ride Safe
Bike-Doc
Jan 31, 2012 | kawasaki Motorcycles
Ihave a drop foot from a driveby shooting.and i cant shift gears what can i do? i have a 94 suzuki gsx 600
what does a "drop foot" entail? if you cant shift its bad linkage or bad tranny. are any parts of the shift linkage touching each other or the case? can you push the bike with the clutch in and in gear, if you cant your tranny is toast.
Jun 13, 2010 | 1994 Suzuki GSX 600 F (Katana)
Boating Logo
63 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
