Question about Toro Garden
Toro 6500D reelmaster not lifting units of floor?
2 Suggested Answers
harlan301
  • 205 Answers
SOURCE: were can i get hold of a manual for a toro
try an go to the toro web sit thy have some pdf down loads. i hope this help. if not let me know i'll check my supplers and see.
Posted on Oct 15, 2009
How do I replace a fuel tank on a toro 38586 snowblower that is leaking?
You need to remove the body cover first. The fasteners are all around the edge of the cover. Once that is free you remove the gas cap and lift off the ocver. The tank is only held on with a couple screws. A new tank can be sourced online for about 30 bucks. At bit pricey I know but it is a discontinued unit. Be safe and good luck!
Nov 22, 2014 | Toro Garden
How do you push a toro riding mower
riding mowers have a bypass system to be able to move a machine that's not running. At the rear of unit you will find a heavy wire coming out the back end lift a little and pull this out. you should now be able to push unit
Oct 18, 2014 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro reelmaster
Sounds like your carburetor may be clogged?
Could also be a dirty fuel filter?
Aug 19, 2014 | Cars & Trucks
Install lift rod too
Jun 21, 2014 | Toro Garden
Flat right reat tire. Cant get a jack under to lift tire off ground to take it off. Can't lift front enough to get block under that might raise rear after lowering front. How's it supposed to come...
Hello there, the Toro 52" 27hp z master has an Exclusive Toro Z Stand on 27 hp (20.1 kw) models provides an on-board tool to simply elevate the front end of the machine and provide access to the underside of the deck.this Z stand gives access to the underside of the unit to enable you insert a jack under to change the rear tire.rockmeister_15.jpg
Here is a link to help you download the service manual, operator manual, parts catalog and setup instructions. These give more insight as regards getting the tire changed.
Hope this support has been helpful?
Thank you for visiting FixYa.
Aug 10, 2011 | Toro 52" 27hp Z Master Zero Turn Lawn...
Where is the choke on a 4500 Toro reelmaster?
There is probably no choke, it is an automatic choke built into the start/stop lever. If it wont start
there is a need for a repair.
Mar 26, 2011 | Sport & Outdoor - Others
My mtx thunder 6500d amp hums when connected light turns on but no output
Make sure you have a proper ground wire connection. The ground wire should be connected solidly to the vehicle chassis in a paint-free location. If it is loose or there is paint t the connection site, you will have problems with the amp output. Also check the speaker wires to see if they are touching the vehicle chassis. This will cause a short circuit and you will not have output from the amp. Finally, check the leads from the head unit. They should be RCA cables, and should have a good connection to the amp.
Feb 22, 2011 | MTX Thunder 6500D Car Audio Amplifier
Can you run two mtx 6500d amps in parallel for more power?
Not suggested to parallel the output of two amps. Instead take each amp, find out what the amps lowest impedance it can drive is and select your speakers based on that. According to MTX these are stable down to 2 ohms without a rated output power of 500Watts X 1. If you get two dual voice coil subwoofers with each coils characteristic impedance of 4 ohms, when you parallel the two coils you will get a 2 ohm load. Just maek sure the speaker can handle the 500 watts.
Jan 27, 2010 | MTX Thunder 6500D Car Audio Amplifier
I have a brand new soundstream xxx 6500d amplifier and when i installed it for the first time protect mode light come on even without rca jacks and speaker wires hooked up. any1 can help?
You need to plug in the RCA and speakers you could blow the amp. The amp is sensing no Input and No output. I would unplug the amp wait around 30 seconds then install the rca and speakers THEN install amp to battery + cable. You should be ok.
Jan 24, 2010 | Soundstream Xxx-6500d Power Amplifier Xxx...
Were can i get hold of a manual for a toro reelmaster 450-d? free if possible!
Oct 15, 2009 | Garden
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
