Question about Berkel Food Mixers
Berkel slicer stops in the middle of slicing - Berkel Food Mixers
How do I install the shredder?
You need to access the accessory attachment point, it's behind the silver KitchenAid logo on the front of the mixer. You'll need to unscrew a set screw (black knob at the very front of the mixer head), newer mixers have a hinged cover, on older mixers, it just pulls out. Unscrew the set screw a bit and fold up or remove the cover.
Now you will see a hole with a hollow square shaft inside, this is where the various optional items attach to the mixer.
Specifically for the shredder, you will need to attach a slicing drum to the drive shaft provided with the shredder, insert it through the drum, and raise the little bar in the rear of the slicer assembly.
Insert the whole assembly into the front of the mixer so that the square drive shaft shaft fits into the square hollow in the mixer, then lower the little bar to lock into place.
Dec 31, 2015 | KitchenAid kitchen aid"" classic stand"
Tip
Great place 4 parts
If u need parts, mixer,slicer parts for Hobart, Anvil, Berkel and more u may want to give (www.onesharpstore.com) a try. Great pepole to deal with
Harry Oooooooooo
on Mar 10, 2009 | Hobart A200 Stand Mixer
How do you adjust the height of the Berkel FMS20? Attachment scraping bowl
There is a screw in the neck of the base, near the mixer pivot.
Jan 14, 2013 | Berkel Food Mixers
How do you remove the cutting blade on hobart model 410
The disc in the middle of the blade unscrews. A glancing blow with a rubber mallet will sometimes break it loose.
May 31, 2010 | Hobart Food Mixers
How can i get a service manual for the berkel model fms30
berkel is owned by itw and they are not inclined to let service man. out
Nov 06, 2009 | Hobart A200 Stand Mixer
How to adjust the slicer attachmenton the mixer attachment
take the attc. apart on the back btm of thecutter assy. there is a hand nut loosen shaft should slide either up or down depending on the thickness you want then tighten nut
Nov 03, 2009 | Hobart A200 Stand Mixer
Hello...I am looking for specs for the Hobart 300 slicer....does anyone have them? I would appreicate your help...Diana dlbwholesalers@hotmail.com The county is requesting them as soon as possible...I...
Hi Diana. Have you given us your complete model # for your slicer?
I can't find a listing on Hobart's website for a 300 slicer. Is there a digit missing in your description?
You could call your nearest Hobart parts place and ask them to email your specs. ASAP.
If this solution has assisted you, please rate it. Good luck! ricardok45
Mar 24, 2009 | Hobart Food Mixers
I bought the slicer and shredder set for the KitchenAid stand mixer, no instructions were in the box. What speed do I use the attachments on?
Your attachment speed will depend on what it is you're slicing or shredding. Begin at speed setting two and work up to the speed where the motor begins to labour, then reduce the speed by one notch. Always start too slow, then move up. If you find this solution usefull, please rate it. Good luck. ricardok45
Dec 05, 2008 | Hobart A200 Stand Mixer
Hobart slicer
Use a hammer and punch.Hit the nut in the middle of the knife to the left,unscrew then remove
Jun 09, 2008 | Hobart N50 Stand Mixer
Food Mixers Logo
23 people viewed this question
Top Berkel Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Berkel Food Mixer Expert? Answer questions, earn points and help others
