Question about Hoover Vacuums
Replace handle release pedal on Hoover dm 4490
5 Suggested Answers
SOURCE: Handle foot pedal release U6425-900
If you look under the vacuum where the latch is located, it is held in place by tabs on either side of the latch. The latch had a pin that holds it in place. You need to insert a small flat blade screwdriver to bend these latches back carefully to release the pins. Once the pins are freed, the latch can be pulled out the top. The replacement should be installed in the same orientation by pushing in from the top until the pins on the latch snap into place.
Posted on Sep 06, 2008
  • 190 Answers
SOURCE: How do you replace Hoover Handle Release Pedal on
The handle pedal is snapped in to the base, where it pivots.
The pedal needs to be pried away fron the base, exposing the pivot pin to release it for removal. On your model, you will likelly have to remove the lower handle from the base (where it pivots) to get room to release and replace the pedal.
Posted on Mar 12, 2010
theogreen1
SOURCE: The handle release pedal wasn't allowing the handle to lower. I took off the pedal and saw the spring load part was broken. What is this part and how to replace it? Bissell 3760-3 handle release
Order Slider Release (7.93, vacpartswarehouse) Pull off 'tank.' Remove 3 Screws for Foot Detent Lever. Pull off. Remove old slider release and spring (verify it's broke.) Replace with new. I just did this today after a year of dealing with it.
Posted on Mar 23, 2012
small6363
  • 18402 Answers
SOURCE: replace handle release pedal on a vax power 6
http://support.vax.co.uk/power-2-upright
Posted on Apr 18, 2013
How to change the release pedal on Hoover SteamVac F5914-900 SpinScrub
99 out of 100 times it's not the handle release pedal that's broken. it's the knob on the rear housing broken off. You will have to replace the rear housing. Take it to a local vac shop for repair.
May 07, 2017 | Hoover Vacuums
Can't lower handle on Hoover wind tunnel vac U6432-900
Anne, Do you mean that when you depress the pedal on the left side of the machine body that you can't get the upper portion to release into a lower mode? Or are you fully depressing the pedal?? As for the switch for the self propelled mode, that's actually just a small button that you move around in the slot of the handle to select which mode you want to use. It's not actually a switch. If you are fully depressing the handle release pedal and it's not releasing, you should take it to the store where you purchased it, if it was a vacuum store. If you bought it at a big box store, then you'll need to take it to some repair shop that does warranty work, if it's within the warranty period of course.
Nov 10, 2013 | Hoover U6437-900 / U6439-900 Windtunnel...
Cannot remove handle from Hoover Dual-Power Carpet Washer
Cannot remove handle or release handle?
Release from the center pedal at the rear of the unit. Rove the handle with 2 long narrow bolts located near the half way point from handle grip to the base; don't loose the two small nuts or you'll have a bad time.
Nov 06, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Need to preplace handle release pedal
To remove the old pedal, simply insert a screwdriver along it's outside edge, and pry upward to pop it out. The new pedal, (#38434026) can be pushed into place with your fingers. Install it with the handle in the upright position.
Feb 18, 2011 | Hoover U8147-900 WindTunnel V2 Bagless...
Mar 11, 2010 | Hoover Vacuums
Stand up lever is plastic, broke when stepped on to release handle, can it be repaired, replaced with a better one, plastic breaks too easily?
The pedal release can be replaced but the base will need to be checked for cracks as well. if the base is broken most common is the socket the pedal release snaps into. some of the plastic parts have been made with better materials
Oct 20, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Hoover savvy handle release pedal does not retract. There does not seem to be any mechanism to force it back, is something broken or missing, like a spring?
yes the handle release pedal is broken. i have the same problem and ordering the spare as i'm writing this email
Jul 07, 2009 | Vacuums
I have the exact same problem. I can't even open the unit up. Let me know if you found anything out. I have searched the web and can't even find a service manual to purchase ! Thanks.
Apr 08, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
13 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
