Question about Garden
Lawn mowres need to know the ignition switch wiring for Honda HF1211 lawn mower
  • 313 Answers
SOURCE: Lawn mower
check out murray & tecumesh website
Posted on May 29, 2008
boscia
  • 163 Answers
SOURCE: charging wireing diagram on craftman 42'' riding lawn mower 19.5'' briggs motor
the charging system runsfrom a stator which is underneath the flywheel and runs to a rectifier/regulator module and to the battery. it will power the blades if it is an electric clutch system and also the fuel plunger system on the carbuerator
Posted on Nov 30, 2008
SOURCE: I have a 1993 murray lawn tractor 12.5hp Ignition Switch????
Take an ohm's and amp. meter and go to the ohm's setting and see which terminals are off and on. If you want to kill the engine put it on the off side. If you want to run anything put it on the start and run side of the switch. Hope this clears things up a bit. donnyb60.
Posted on Mar 24, 2009
  • 3074 Answers
SOURCE: wiring schematics for 2007 cub cadet lt1045 need
this should help Tim:
http://cubcadet.custhelp.com/app/answers/detail/a_id/1722/~/cub-cadet-technical-service-manuals
Posted on Jun 04, 2011
randyfenske
SOURCE: i have a honda riding lawn mower h4518h and i am
I had no spark on my 4518 and used a hair dryer to heat up the electronic brain box that connects to the coil and it started immediately- I was amazed but it worked- need to order a new electronic control module
Posted on May 31, 2012
Wire up ignition switch
you tube has heaps of vids to help you.
Sep 13, 2014 | Mtd Garden
Why key start for craftsman lawn mower doesn't work
The ignition switch could be bad. NAPA has replacement switches. Disconnect the old one and take it with you and have it matched up. Be sure to draw a diagram of where the wires go. Everything needs to match perfectly.
May 27, 2014 | Craftsman Garden
Where is the cut off sensor for honda ride on mower
Theres more then one theres probably three to five one for blade one for brake one for backup one for seat take your pick they all run off the one wire that comes from your ignition coil .If you just want to see if its the switchs take off cover of engine and pull the small wire off the coil that will bypass all the switches .Its a start
May 08, 2014 | Honda Garden
Lawn mowres
Can't find one for you. Do you have a manual, may a diagram.
Apr 19, 2014 | Garden
Troy Bilt GTX 18 lawn mower engine won't continue running
ck. to make sure the wire to the ignition coil is hot. may need to replace the ignition switch.
May 24, 2013 | Garden
I have a Honda HT4213 lawn tractor, it does not have any spark. I checked the seat safety switch. It's good. pto switch, good. Neutral switch seems good. Engine does turn over but as I said no spark.
Flywheel and ignition coil are located on the rear of this engine. Remove covers as needed to reach the ignition coil. There are two (2) High-Tension leads (to the spark plugs) and one (1) small-guage wire.
The smaller guage wire is the engine's "Kill Circuit" trigger-wire. Everything electrical that makes the engine stop running comes back to this wire. Unplug it and check for spark with a spark tester.
SEE NOTE BELOW
If no spark, replace the coil. Part number 30500-ZA0-701.
If good spark, continue your wiring checks, possibly the control relay part number 38350-762-003 located roughly in the left rear of the engine bay.
NOTE: DO NOT START the engine with this kill-wire unplugged! There will be no way to turn it off until it runs out of fuel! Remove the spark plugs and use a spark tester and above all, BE SAFE!
Hope this helps,
Dolf-
Oct 13, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Solenoid wires to be replaced
I posted this for a similar question.
The large red cable from the battery should go to the large terminal on one side of the solenoid. The opposite side of the battery solenoid connection goes to the starter So now you have a heavy cable going from the battery to one side of the solenoid and another heavy cable (red) going to the starter connection. There should also be a small wire coming from the ignition switch to the small terminal on solenoid. If there are two small terminals on solenoid, ground the other one. To test the ignition switch, just turn the key and see if you get 12 volts, then you know that part is good. If not, check your ignition switch. So, back to the solenoid-----. If there are two small solenoid terminals with nuts for wires on the solenoid then the wires could be mixed up. So just reverse the two small wires and try again.
You would think they would make things easy and say on the solenoid, Battery connection here, and Starter connection here, and ignition switch wire here, but no, just nothing for the most part.
So now remember this is nothing more than a lightswitch type of a mechanism where instead of using your finger to flick the switch, we are using a small electric charge to momentarily close the light switch, in this case the starter motor, same idea.
Sep 02, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Need wire schematic for starter switch
I am holding the switch part (INDAK 681064) with the black pushbutton switch to the right.
The two wires on the top are Red then White. The two wires on the bottom are both black.
Apr 10, 2009 | Black & Decker 19" Electric Lawnhog...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
