Micromark mm53507 Hose adapter wanted
Does anyone know where I can purchase spare parts for a Micromark storage heater? I need the control knobs to replace the missing ones.
DEAR SIR
please search it near of your micromark area dealar you can buy it from there , and for know the micromark dealer location try to find it via internet then you can know it,s location .
hope answer the question
thank you
please vote !
Sep 15, 2010 | Heating & Cooling
On my wslp1100 model its very very hard to connect the hose to the faucet adapter, it just does not want to go in ,also it leak's a lot of water from where the hose connects to adapter , I have to wrap a...
Hi... I had the same problem. Instead of trying to figure out the faucet/adapter issue (was too pissed off) :) I took my old washer hose and just used that. Connect the washer hose to your sink and the washer just like it would be if you used that adapter hose. You will want to make sure it is tighten good or it will leak a little...and make sure that the adapter hose end is in your sink because that is where the used water empties out from.
Hope this helps.
Aug 06, 2010 | GE Spacemaker WSLP1100D Top Load Washer
We have a faulty Micromark tea urn rated 1500
Try espares.co.uk..they may help..the130 may be the cut off temp in which case ant TOC would do provided that its the same dimentions
Apr 09, 2010 | Microwave Ovens
Where can i get instructions for a Micromark MM52121 Tea Express?
Hi, did you find any as I'm in the same boat and as Micromark have folded can't find instructions anywhere
Thanks
Dec 28, 2009 | Coffee Makers & Espresso Machines
Can't find the scart and power adapter plus the wire has been cut
cant find power supply to my micromark camera .how do i hook up to tv and what do i need
Apr 25, 2009 | Cameras
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
