Question about RTO Bodyguard T300 Commercial Treadmill
Precor m9.35 treadmill power comes on but belt will not start
Horizon manual
once lubrication is complete, reset the console by pressing and holding STOP and SPEED + buttons for 5
seconds
Aug 02, 2014 | Precor Treadmill Belt/Deck/Lube Kit,...
Error 27
Precor Error 27, Too Much Drive Motor Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  1. Check the amp draw using a clamp on AC volt-amp meter during loaded and no load conditions and compare values to a similar treadmill that is known to have a good running belt and deck. Replace the belt and/or deck if necessary. Don't forget, some units have a double sided deck which means it may be flipped over rather than replaced if it has an unused side.
  2. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 27
Feb 18, 2014 | Precor 933 Premium Series Treadmill
Treadmill keeps stoping
Corrective Action
Jan 27, 2014 | Life Fitness Treadmill Precor C954 (Used)
My treadmill stops wen runing on it and brings up er 27 on screen
Corrective Action
My treadmill stops wen runing and brings up er 27 on screen
Corrective Action
I have a precor c956i and got error 27 on it, what can i do to resolve probmem? thank you
Corrective Action
Sep 27, 2013 | Precor C956i Treadmills with HR /...
Power keeps cutting out when clients are running on it.
When a running belt has excessive wear, it creates a lot of friction which causes the drive motor to work harder. When the drive motor works harder it will start overheating. If the belt is not lubricated periodically, it will ruin the deck, the drive motor, and cause other electrical problems such as tripping the breaker [after a while, the circuit breaker on the treadmill will need to be replaced.
It is suggested to lubricate the belt every month. At this point, you may need to replace both your deck and your running belt.
With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Parts for 952i 954 954i 956 956i Treadmills SPORTSMITH net
Apr 16, 2011 | Precor C956i Treadmills with HR /...
What does error 29 mean on a precor C954i?
Precor Error 29, Excessive AC Input Current Probable Cause 1. The running belt and/or deck are badly worn.
2. Bad lower PCA.
3. Drive motor is shorted or de-magnetized causing a high power demand.
Corrective Action
  2. Test unit with a known good lower PCA. Replace lower PCA if necessary.
  3. Test unit with a known good drive motor. Replace drive motor if necessary.
Precor Error Code 29
Apr 06, 2011 | Precor C954i Commercial Treadmill
Where can I buy a replacement walking belt for a Precor 9.21 treadmill?
FitnessRepairParts.com has a walking belt for Precor 9.21 treadmill (it says it is used on four different versions of the 9.21... make sure your specific model number is listed)
Jan 12, 2011 | Precor 9.21 Treadmill
RTO Bodyguard T300 Commercial Treadmill Logo
16 people viewed this question
Top RTO Exercise & Fitness Experts
Jim London
Jim London
Howard
Howard
Jax Planet
Jax Planet
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
