Question about Maytag Kitchen Ranges
Merh865ras troubleshotting Taking a long time heating the oven
Oven only heats to 215 degrees will not get any hotter.
Sounds like the heat sensor is bad. I'm assuming this is an electric oven. On the inside back wall of the oven you will see a metal rod sticking out. Unplug the stove, take off the back cover and you'll see where it's attached. Unscrew the keeper and pull it out through the back. Unplug it from the wiring harness.
Apr 15, 2012 | Ovens
Oven either not heating up at all or taking a very long time to heat up.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101 ;'
Jul 23, 2011 | Whirlpool AKZ159IX Oven
Ge oven will heat up then the pre heat will beep then oven shuts off and the time light will flash 0
heatman101
Apr 01, 2011 | GE Profile JTP18 Electric Single Oven
Oven takes a long time to preheat and will not stay heated
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
heatman101
Feb 14, 2011 | GE Ovens
My oven now takes a long time to pre heat. Is there a solution?
heatman101
Jan 19, 2011 | Kenmore 72002 / 72004 Kitchen Range
It heats up..But it seems to take a really long time to preheat to the right temp
heatman101
Dec 27, 2010 | Ovens
Oven do not heat up
try resetting the time on it! thats works for me!!!!!!!!!!!!!!!
Dec 22, 2010 | Hotpoint Ovens
Oven is taking a long time to heat...15 minutes and it barely reaches 200
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more deatil about your problem.
heatman101
Aug 31, 2010 | Bosch Integra 700 Series HEI7152 Electric...
Oven taking forever to heat up
The Oven heating Element is open circuit. Change the element.
Aug 01, 2017 | Kitchen Ranges
Oven taking a long timt to heat to temperature
Try shutting off the breaker for about 10 minutes - then bring the power back on
Sep 20, 2007 | GE Profile JT912 Electric Single Oven
Kitchen Ranges Logo
12 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
