Print job disappears withouth printing in Quickbooks
I just installed the officejet pro 8500 and it seems to be working fine and i can print in Quickbooks to the fax but not the printer itself. it shows it is printing then disappears. i tried reinstalling it, but it still won't work in Quickbooks. Any ideas?
  • 1 more comment
  • advancede1 Jun 19, 2009
    There isn't anything there, it will show up then disappear without printing a thing. I can print in other programs but not Quickbooks.
    If i put the printer offline it shows up in the queue but once i put it back online it disappears again. I've also reinstalled Quickbooks and that was no help either.
    Yeah, I can print in other things and I've tried searching their online support with no luck, guess i'll keep trying. thanks!
Go to the printers folder, right click the printer and chose properties. Under properties go to the advanced tab and check off print directly to this printer. I work with HP and find this solves the problem of printer 95% of the time
Posted on Aug 11, 2009
Thanks rjcm7
my case was about installing HP 1220c printer on win 7.
default settings used to send the print job to the job queue but disappeared immediately. ur solution eliminated the problem
thanks
Posted on Apr 29, 2010
    Genius:
  • 1,018 Answers
Click on the printer's icon at the bottom right of the screen. Display the Print Queue.
You will probably find several print jobs in the queue. Go into the queue and either release the entire queue or release each job.
Don
Posted on Jun 19, 2009
  • Don  Farrell
    Don Farrell Jun 19, 2009
    Okay, let's see if we can trap the print job. Place the print queue on hold.
    First, make sure that this printer is your default printer. Next make sure that the driver is set to go to this printer.
    Now go into Quickbooks page setup and make sure that the application is going to print to this printer.
    Print the job. Doe the print job now appear in the queue?
    Don
  • Don  Farrell
    Okay, we now know that the data is going from the driver to the print queue.
    So the failure is occurring between the PC and the printer. Can any other application print correctly to the printer?
    Either we have a hard failure on the printer or the application (Quickbooks) is causing you the grief. For that you will have to go to QuickBooks technical support.
    Don
HP Officejet Pro 8500 Printer does not print the last line
Try uninstalling the driver and reinstalling it by going to HP's web page. Before doing so, defragment your C drive.
Oct 22, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Printer suddenly stopped working with quickbooks but will still work with all other programs. window states: change port assignments or reinstall software. printer is hooked up wirelessly
  1. Open the QuickBooks sample company and try to print the same form or type of form. If it prints successfully, your company data, form template, or customized report may be damaged.
  2. Reopen your company file and try to print an uncustomized (standard/default) form template or non-memorized report. If the issue occurs again, refer to Verifying and rebuilding the QuickBooks company data and then attempt to print again.
  3. If you were printing a batch of forms in QuickBooks, attempt to print a single form. If successful, try printing smaller batches.
  4. If you were able to print from QuickBooks in the past from this company file:
  5. Turn off the printer, restart your computer, and then turn the printer back on.
  6. In QuickBooks, choose File > Printer Setup and check the printer settings for the specific form you're trying to print.
  7. Click Help in this area for more detailed instructions on these settings.
  8. Ensure that you have the latest printer drivers for your printer. Go to the manufacturer's website to download and install the most current drivers.
  9. Replace the QuickBooks Qbprint.qbp file:
  10. Close QuickBooks.
  11. Rename the qbprint.qbp file.
  12. Open QuickBooks and attempt to print again.
  13. If the issue persists, repair the QuickBooks installation.
Mar 07, 2010 | HP Officejet Pro L7680 All-In-One Printer
Quickbooks forms will not print on newly installed HP 6500
I deleted the qbprint.qbp file and that fixed it for me. Aggravating regardless.
Feb 15, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
My HP 8500 stopped printing my Quickbooks 2009 checks. It worked fine for about 5 months and then stopped. I installed updates for both Windows and QB 2009 and reinstalled the HP drivers for my printer but...
click on start go to control panel. go to pritners. click on add a printer option on top of window. then add a local pritner. add deskjet 990c drivers use existing ports
Dec 16, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
I have a officejet pro 8500. I have a problem printing envelopes
Check two areas
1.. It could be the software your using to print the envelops.
2...It could be the printer driver.
Go on HP's site, and check and see if there has been any updated printer driver, or patch file. Hope this helps.
Dec 21, 2017 | HP Office Equipment & Supplies
Can't type date into .pdf file and print with HP OFficejet 8500
Maybe it is because of your PDF file is encrypted by author with owner password. In this case, you can remove the password by AnyBizSoft PDF Password Remover, and then print it again.
Hope it helps.
Nov 17, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Hp 8500 officejet won't print PDF files; word, quickbooks all work fine.
You need to go into Printers/Properties/Advanced
Select checkbok Spool Print Documents. Then it will work.
Sep 17, 2009 | HP Officejet Pro 8500 Wireless All-In-One...
Quickbooks Pro 2007 Printing Blank Invoices
Go 'Lists' and then open 'Templates', double click on the product invoice and make sure the invoice is 'Active'.
Qbooks saves printer settings for each feature, regardless of which is set as 'default' in Windows...be sure you have the correct printer selected.
If the above are set correctly, go to HP's website and download the latest driver for your printer.
Jul 13, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Hp6500 won't print my invoices from Quickbooks, Help!
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
Jun 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
1,769 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
