Question about FXLAB 30 mW Pulse 1 Green Laser System with 50 Patterns G018EA
Laser beam fuzzy not sharp.
The beam is nowhere near as defined as the other pulse 1 I own. Tapping it gently sometimes a sharp tap helps.
Bathroom sink single handle danze faucet. I removed set screw, but the handle won't come off. How hard can I pull?
Alot of variables there. If it's really old you must be extremely gentle. I have had them crumble into pieces in my hand. If it doesn't appear corroded around the edges and is in good shape, you should rock or pry gently with a non marring tool (putty knife covered by rag) alternating sides to break it loose. A penetrating oil like PB blaster can be used if you can let it sit for a day. Just straight pulling is not wise. Tapping (not pounding) can be helpful. You are just trying to break the bond between surfaces so the vibration of lots of light tapping will sometimes do it.
Jun 09, 2016 | Danze D203112 Melrose Single Handle...
Hi ive had a fishman pick up installed under saddle of my accoustic guitar its fine but something is wrong becuase wen im slapping the strings and tapping guitar the sound goes very quiet for around 1...
It is possiblle that the sudden pulse from the pickup due to tapping is saturating the input of your amplifier, and that is what actually kills the signal. Try this into a different amp as a test. Once you do the test I can offer some suggestions to try.
Apr 23, 2011 | Fishman PRO AG-094 Under Saddle Acoustic...
Error code E45 when powering on. It is a V705
Try tapping the side of lens, or smacking the camera gently on the palm of your hand when it's on, then restart the camera. It could be a problem with the lens mechanism, and the gentle, yet firm tapping may help.
Mar 01, 2011 | Kodak EasyShare LS753 Digital Camera
Outside thermometer mercury has separated giving incorrect reading
Great!-- It has been awhile since I have done this---
and be careful, for you know how dangerous mercury is---
(Your Thermometer might be another liquid-- if it is red?)
Anyway, here is what you can try:
If you place the thermometer in the freezer for a few minutes, yo will get the liquid to move toward the bulb--- GENTLY!!! tab the Thermometer on something like a wooden board, -- something firm, but not steel, or ceramic-- or something real hard-- Gently tapping, will move the separated column toward the bulb, too--
Now place the bulb in in warm water--- gently tapping again--
Did any of the column join-- Repeat a few times-- did that work?
You can gently warm the bulb, and column, too--
HOWEVER TO NOT get near the maximum temperature of the numbers on the thermometer, or you might break the glass column at the top!;
;Let us kow how you made out!
Mack B
Jan 18, 2011 | Heating & Cooling
LENS-CAPPED appear , even though the cap had been taken off already. can't record. why?
Usually this message (with the cap actually off!) means that the internal iris is stuck closed. This can occur for many reasons. The problem is that this is not a DIY repair. You can try tapping the lens assembly with your finger. Sometimes the vibration of that tapping will release the iris. If that fails, then the only way to resolev it is to gain access to the assembly inside the camera. Again, this is not a DIY repair unless you have previous experience with camera repair. The internal cables and parts are easily damaged. When attempting the "tapping", strike the camera near the printing that is close to the visible lens. Please be gentle, do not strike hard, just a firm tap.
Keep us posted on your progress,
Dan
Dec 13, 2010 | JVC Cybercam GR-D93 Mini DV Digital...
My p205 Toshiba notebooktouchpad has a tendencey to activate the start menu inadvertantly ,like 90% of the time,when i tap the pad but works fine when tapping the left or right buttons,and the pointer is...
It may actually need replacing. However, first go into control panel and reset the options for the touch pad.
If this still occurs, you can actually open your laptop and, with a replacement from toshiba, change it out.
If you are concerned about this, post a reply and I'll give you steps how to do this.
Aug 21, 2009 | Computers & Internet
1999 Buick Century
It sounds like either the headlight relay is shorted, or the switch is shorted. I'd think that the relay would be in an underhood box, probably near the battery (although there may be several boxes under there). You can swap it with another relay of the same rating (they're usually color-coded in reference to their amperage, so two of the same color would be interchangeable) and see if that works. If not, I'd think maybe the switch needs to be replaced.
Another idea - are these the actual high beams (as in the switch is turned on) or are these the daytime running lights? If it's the daytime running lights, I'd suspect the relay for those (which is separate from the normal headlight relay). You can even try tapping firmly on it a few times with a wrench. A relay is a mechanical switch and they stick sometimes - popping it with a wrench or screwdriver handle sometimes unsticks them.
Jul 30, 2008 | 1997 Buick LeSabre
Front End Noise in 2005 Nissan, Maxima
it would not hurt to check rear tire wear due to misalignment
cupped tires will cause a faulty bearing type noise or humming.
Jun 15, 2008 | 2005 Nissan Maxima
FXLAB 30 mW Pulse 1 Green Laser System with 50 Patterns G018EA Logo
529 people viewed this question
Top FXLAB Electronics - Others Experts
Are you a FXLAB Electronics - Other Expert? Answer questions, earn points and help others
