Question about Siemens Gigaset 2420 Cordless Phone
Base station not getting registered - Siemens Gigaset 2420 Cordless Phone
2 Suggested Answers
CORDLESSGURU
  • 106 Answers
SOURCE: Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Posted on Feb 10, 2008
I cannot register the handsets to the new base station I had an 8100-2 base that quit working. I bought a new 8100-1 base. Can I change the MAC ID on the phones so they will accept the new base station?
If you cannot register the handset then here are some possible causes and solutions for them.
Cause 1:The handset and the base station were not prepared for registration.
Solution: Unplug and then plug in the power adapter.
Cause2:The handset or the base station has not been entered into registration mode.
Solution: See User Manual for correct registration of base station and handset.
Cause3:The base station is registered full.
Solution: Press [Page Key] on the base station to page the registered handsets, then perform the deregistration operation. Finally, register the handset you want to use.
Here is few more of additional info. if you want:
Register the Handset to the Base Step 1:
Place the accessory handset in the base station of the system. For some simple systems this may be all you need to do to register the new handset. If so, the LCD screen will read "Registration Complete."
Step 2:
Press the "menu" button on the base station, scroll down to "register handset" and press "ok."
Step 3:
Press and hold either "#" or "OK" (depending on the brand) on your handset until your hear the indicator tone. At this time the LCD should confirm the handset is registered.
Reset Handsets with the Base Step 1:
Clear the registration information from the base if you want to register your handset to a new base.
Step 2:
Hold [] and [#] down on the base for a minimum of 5 seconds or until the "System Reset" menu appears.
Step 3:
Choose the "deregister" option from the menu and scroll down to the handset you wish to remove.
Step 4:
Press "OK" to de-register the correct handset. Press "yes" when you are asked if you are sure, and wait for the confirmation tone.
Reset Handsets without the Base Step 1:
Hold [] and [#] down on the phone for a minimum of 5 seconds until the "System Reset" menu appears.
Step 2:
Choose the "base unavailable" menu, select "yes" and press the "OK" button.
Goodluck,
Please don't forget to rate the solution.
Mar 21, 2008 | Vtech IP 811 Cordless Phone
How to reboot soundstation 2w polycom if you forgot the password
egistering Base Station on Polycom SoundStation 2W
Hold down 1,4 and 9 until green & red lights flash. Then hold down the page on the base station.
OR
You can register the base station to the console by:
1. press menu key
2. Select Admin Setup
3. Select Registration
4. You will see "Register with Base Station" in display. Press the Register softkey.
5. You will see "Power cycle base station then press ok". Unplug base and plug back in and press OK softkey.
6. You will see "Press and hold the paging button on the base for 10 seconds"
7. You will see Registering in the display on the console and then it should go to ready mode.
Mar 05, 2010 | Polycom SoundStation 2W (2200-07800-001)...
My phone says no link to base but I am right beside it.
Sounds like the antenna on the base station is not receiving, or the cordless handset is not transmitting -OR- the sets have never been registered to the base station (please look up registering to base station, if the set has never been registered)
Did the cordless set work before?
The base station or the handset may just have a hick up, I would un-plug the base station and leave it un-plugged... now get all the cordless set(s), and take out the batteries from the cordless set(s). Wait for about 15 seconds for all the power to drain out of the sets, then re-install the batteries.
Once all the cordless sets are back up and working, plug in the base station and wait for about 1 minute.
This forces the base station to re-establish and link between the base station and the cordless sets.
Good luck
May 11, 2009 | Panasonic KX-TGA101S Cordless Handset
I have a Vtech 2431 base station with 4 phones, one at the base station and 3 remotes, I need to replace one of the phones but I do not know how to reset the base station to remove all the phones...
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time. Then all you have to do is re-register handsets...
Mar 03, 2009 | Vtech Lands Phones
Olympia cdp24201
1. go to menu, then HS setting, then registration, register
2. follow the steps and register the set to the base.
3.press and hold the base mute button for 10 seconds, press next to continued
4.select the cbs and connect it.
5.enter 0000 as a password
Jun 28, 2008 | Olympia CDP 24201 Cordless Phone
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
Getting a new mobile in the registration mode with my Gigaset 8825 base station.
You need to register the handset to your base. Its easy, but first you need to clear the setting on the handset. Do this by pushing Menu, scroll to base system settings, push OK, then scroll to Base station 1, push OK, then scroll down to deregister, push OK twice, then press End. The handset should now say "please register", of which you can press OK, enter your pin or 0000 and the display should be flashing "registering base station 1". Now quickly, at your base push Menu, scroll forward to system settings, push select, enter your pin or 0000, then select. Push select again and the display should say "registering HS". Now, both displays (base and handset should say registering), keep your eyes on your handset display, once it "shakes hands" with the base it will prompt you to select an intercom number, you can just push OK. If you have problems, repeat the steps or you can download a manual for free at www.cordlessrepair.com
Oct 18, 2007 | Siemens Gigaset 8825 Cordless Phone
Base station
1. press menu key
Oct 12, 2007 | Polycom SoundStation 2W (2200-07800-001)...
TWX977 submersible unable to base register
push menu on base station - select register phone
push # sign on twx977 phone at the same time
phone will register on 9485 base station and unit
Sep 09, 2007 | Uniden TRU9485 Cordless Phone
Siemens Gigaset 2420 Cordless Phone Logo
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
