Question about Panasonic Toughbook Computers & Internet
Bios password No access to bios setup
Cf-30 mk3 Cannot correct date, time, change boot order, enable blutooth and WiFi
harvester3
  • 181 Answers
SOURCE: Satellite A215-S7416 Bios Password
you're out of luck, unless you're familiar with "shorting" the bios chip.
Of course, you can contact Toshiba for a workaround. Proof of ownership is necessary.
good luck
Posted on Jul 17, 2008
BubbaGuru
  • 70 Answers
SOURCE: Bypass Bios password on Toshiba Satllite 5105-S501
ruhh row...The only option I know of is to remove the cmos battery for about an hour. toshiba support may have a "generic password" that can be used.
Posted on Mar 20, 2009
  • 108 Answers
SOURCE: Asus eee pc 4g bios password
You don't need to access bios to change boot drive just hit escape key a couple of times when you power on and it will give you options for which drive to boot from.
Posted on Jun 08, 2009
geo_jonas
  • 555 Answers
SOURCE: Need how to access bios setup utility -Panasonic CF-270 Notebook.
To access your BIOS Setup please restart your laptop then during the first boot process kindly press either the following:
1. F1
2. F2
3. F8
4. F12
5. F10
6. Del
7. Esc
Cause the bios setup is design in different manufacturer of laptop so the best thing to do is read the information during the first boot of your laptop it is always display the keyboard sequence to access the bios setup.
Thanks
Posted on Jul 31, 2009
  • 8 Answers
SOURCE: Acer travelmate 2410 phoenix bios setup utility
u got to replace ur BIOS. but der r ways to recover the BIOS password using default passwords, i need to get to know ur MOTHERBOARD build.
Posted on Mar 31, 2010
How do I reset the bios Password on a Panasonic Cf-51
This method may help;
1) Locate and remove the RTC battery
2) locate and remove the main battery and unplug power supply.
3) depress the power button for 30-60 seconds.
you do not have to solder anything to the board if there are posts ic 61,63 on MAIN PCB then just put a jumper across them while you power up. if its just 2 SMD pads just use a needle probe to arc the connection.
Oct 10, 2016 | Panasonic Toughbook CF-51 Notebook
How can i have the password bios of laptop dell E6420
f you are running Dell servers, it is recommended to enable BIOS password. This is will prevent accidental changes done to Dell BIOS settings by others who get physical access to the server.
You can setup two different types of passwords in Dell BIOS:
System Password: This will be prompted before the system can boot up, and load the operating system.
Setup password: The system will prompt for this password only when you are trying to access the BIOS settings.
Depending on your situation, it might be a good idea to enable both the system and setup password at the BIOS level. I recommend that you at least enable BIOS password.
Press F2 for System Setup
When the Dell server is booting up, press F2 to start system setup, from where you can change Dell BIOS settings.
BIOS System Security
From the Dell BIOS main menu, scroll down to "System Security" and press enter.
Password Not Enabled
From here, you can see that both the System and Setup password is not enabled by default.
Enable System Password (and Setup Password)
Scroll to "System Password" and press enter, which will prompt you to enter the password that you like to set for the system. Please understand that if you set this password, you have to enter this password everytime you start the system. Do the same thing for Setup Password.
Don't forget this bios password. If you forget, then you have go through the painful process of resetting the Dell BIOS password.
Password is Enabled
Once you've enabled both the password, from the "System Security" menu, you'll see that that both system and setup password is enabled as shown below.
password is set
System Password Prompt (During Startup)
From now-onwards, anytime you start the system, it will not load the operating system, unless you specify the system password as shown below.
12345
Setup Password Prompt (To Access BIOS)
If you press F2, to get to the BIOS, it will prompt for the setup password as shown below. If you don't enter a valid password here, you cannot access the Dell BIOS settings anymore.
Dec 16, 2014 | Dell Latitude E6420 Laptop Computer...
How to change to a different date in advanced booting options
To change your system date through Advanced Booting options, you first need to enter BIOS setup menu of your system. To enter BIOS setup menu and to change your system date, you can follow the instructions below:
1.Boot your system and enter BIOS setup menu using the designated key. Though the key to enter BIOS may vary depending upon the computer manufacturer, usually keys like Delete, F12, F10, and F2 are designated to enable a user to enter BIOS setup. To know how to identify the key your system is designated to enter BIOS setup, you can refer to the image under "Method 1 of 3: Enter the BIOS" section on the following webpage:
Important: Following link is of a third-party website. We recommend you to update your security software thoroughly before clicking on the link.
http://www.wikihow.com/Change-Computer-BIOS-Settings
2.As soon as you identify the BIOS setup key, strike it rapidly and repeatedly (while the booting is on) till the time you enter BIOS setup menu. You may get just a few seconds to do this. If you are not able to enter BIOS setup menu by pressing the key repeatedly, reboot your system and follow the same steps again to enter BIOS setup menu.
Note: BIOS menu do not support mouse input. Hence, you will have to navigate through the menu using the arrow keys on your keyboard.
3.Once you enter BIOS setup menu, you can change the date of your system by going to "System Date" option. This option is generally located in the "Main" section of the menu.
Important: The layout of BIOS menu varies from manufacturer to manufacturer but most of them share a few common settings. If you are not able to detect "System Date" option in the "Main" section of the menu, you may need to look into other sections to locate the option.
To get a pictorial explanation of the above steps, you can refer to the following link:
Hope this will resolve your issue.
GuruAid.com
Aug 09, 2014 | Dell Microsoft Windows XP Home Edition
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Cf-30 disable touchscreen
    On all Panasonic Toughbook Notebooks,
    you must get into the BIOS by pressing
    the F2 Function key when you turn on the
    Toughbook as it is booting. Press F2 repeatedly.
    This must be done in the 1-2 seconds before
    Windows starts to load. Then you will see
    Touchscreen usually on the 2nd page with the
    word "Enable". Simply select enable and press
    "Enter" and the choice between enable and disable
    will appear. Then select "Disable" with the cursor
    and then press Enter. Finally you need to
    "Save and Exit" the changes in the BIOS.
    That is it. Good Luck to you.
    Regards,
    Richard - Montreal Based
    Panasonic Toughbook Authorized Dealer since 1989
    Nov 13, 2012 | Panasonic Toughbook CF-30 Notebook
    Irql not less or equal blue sreen cf-51
    reformatting the disk / restore computer back to company settings...is only the resolution for this...
    To reinstall your operating system, you must have a CD drive in your multimedia pocket.
    Note: CF-51 (Mk2) and CF-51 (Mk3) can also boot to an external Panasonic USB CD drive.
    When the laptop is first powered on, the Panasonic name appears in white lettering with the phrase 'Press F2 to enter Setup' directly below it. When this phrase appears on the screen, immediately press F2 on your keyboard. Put the Panasonic recovery CD in your drive and use the arrow keys to move to the boot tab. Change the order of boot so the CD drive boots first. To do this, highlight the CD drive and press F6 until CD drive is the No. 1 listing. Press F10 to save your changes, exit and follow the instructions when your CD starts running.
    Jun 14, 2011 | Panasonic Toughbook CF-51 Notebook
    I cannot boot from the cd rom to do a fresh install of windows xp onto the laptop (Toshiba Satellite 1805-S274 PC Notebook)
    Most computers need to have the boot order reset in the Bios to enable booting from cd. The following should be the correct way to access the Bios setup for this model.
    Starting with the system powered off (not in sleep/suspend or hibernate mode)-Start with the system powered off. Press the power button and then immediately press and hold the Esc key while the system runs the POST (Power On Self Test). When the POST finishes, a prompt will appear telling you to press the F1 key to enter BIOS Setup. At that time, press the F1 key to access the BIOS Setup program.
    Once in the Bios setup, change the boot order to boot first from cd, then save changes and exit. You should then be able to run the cd install.
    Oct 22, 2010 | Toshiba Satellite 1805-S274 Notebook
    My computer won't start up right
    press F1, when it boots you are going to have to go down to the date and time, and click on it then you will need to put in the correct day date and time. If pressing f2 it will take you into the bios, and you can set it from there prior to booting, unless you know what you are doing, stay away from the bios, it can really screw up your computer. Good luck and Peace,Gym
    Dec 17, 2008 | Dell Dimension 4600 PC Desktop
    Computers & Internet Logo
    18 people viewed this question
    Top Panasonic Computers & Internet Experts
    Oloyede Monsuru
    micky dee
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
